Sharp LC-40LE550U no backlight
  • krygods
    replied
    Re: Sharp LC-40LE550U no backlight
    ok cool, i'll go ahead and set it to a comfortable low level before it goes to a new home.
    replied
    They should have good thermal management, I would set the BACKLIGHTS LEVEL (not the brightness/contrast) to as low as you can so the LEDs will run cooler and extend the life of the LEDs.
  • krygods
    replied
    crazy thing is that four out of 5 led strips are mounted to the panel casing which is plastic, only the second strip from the top is mounted on a strip of metal. I was under the assumption that the LED strips needed to be mounted to metal which acts as a heatsink?
  • krygods
    replied
    I believe it was 10 LEDs per strip 5 strips
    replied
    So how many LEDs are in one strip? 4 LED strips?
  • CapLeaker
    replied
    perfect!
  • krygods
    replied
    disassembled the panel to test the leds, found bad solder joints on one the of the connectors that join the two separate strips into one long strip. turned it on and the leds blinded me.
  • krygods
    replied
    P/N for UD101 is RT8300
  • retiredcaps
    replied
    BTW, what is the marking in IC UD101, just right of 47uF 450V cap?
  • retiredcaps
    replied
    Hmm, from
    https://www.sharpusa.com/ForHome/Hom...C40LE550U.aspx
    4 million: 1 dynamic contrast ratio
    Without even seeing the TV, I think I will call
  • retiredcaps
    replied
    Originally posted by krygods
    This TV powers on and off and I can see the floating screen saver very faintly with a flashlight.
    If the TV is in a very dark room, do the LED backlights flash even for a brief time?
  • retiredcaps
    replied
    13 - 375mVDC and rising???
    pin 13 is NC. The 357mV reading is just your multimeter on high impedance with some ghost readings. NC is probably not connected to ground otherwise you would get 0V.
  • retiredcaps
    replied
    CN201
    3 - 112mVDC
    14 - 3.18VDC
    It would make things easier for us if you put the description of each pin next to the readings.
    CN201
    pin 3 - ACD
    pin 14 - BL_ON
    On most sets, BL_ON (backlight on) going high (> 3) means turn on. On some sets, it might be the opposite.
    ACD might be AC Detect. On some sets, ACD high might be needed to turn on. Or it could be the opposite.
    When the TV is in standby mode, what is the voltage of pins 3 and 14? When turned on what is the voltage of 3 and 14? When the set is turned off, what is the voltage of 3 and 14?
    Wow, 329V DC into the LEDs. Nearly a 55 to 52 volt drop between each strip of LEDs. At least it has decent 47uF 450V cap there.
  • krygods
    started a topic Sharp LC-40LE550U no backlight
    I've measure voltages and here is what I've found
    CN201
    1 - 3.25VDC
    2 - NC
    3 - 112mVDC
    4 - 3.19VDC
    5 - GND
    6 - GND
    7 - GND
    8 - GND
    9 - 12.45VDC
    10 - 12.45VDC
    11 - 12.45VDC
    12 - 12.45VDC
    14 - 3.18VDC
    15 - 0.67VDC
    16 - NC
    CN202
    1 - 329VDC
    2 - GND
    3 - 275VDC
    4 - GND
    5 - 221VDC
    CN203
    1 - GND
    2 - 168VDC
    3 - GND
    4 - 116VDC
    5 - GND
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • Misterfixit
    Sharp LC-58Q7330U No Backlight
    by Misterfixit
    This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
    06-04-2023, 07:39 PM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Misterfixit
    sharp LC-50LB601U No backlight
    by Misterfixit
    I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
    04-04-2023, 01:21 PM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
