Samsung UD65HU7200F smart tv - vertical lines on display
  • bronstine
    • Jun 2015
    • 6
    I am bought a Samsung UN65HU7200F tv from a neighbor very inexpensively. He stated that it just stopped turning on, but the year and a half prior to that, it was great. I replaced the power board and everything worked. However, there are some vertical lines on the screen on the left side (mostly white, some colored stripes), and faint alternating grey/light stripes on the rest of the screen. (see pictures)
    I ordered a replacement T-CON board and installed it. No changes whatsoever.
    I have checked the tab bonding, and on the left side, it flickers when I press on it, but doesn't go away. I haven't found any connection that changed any other aspect of the display. I placed some thermal padding on the left tab (as shown by Bud M-thank you btw), and it didn't change anything.
    I'm not sure what to do next. Could the main board cause these problems? Can the tabs/boards on the TV be replaced?
    Any help is appreciated. Thanks!
    Christine
    Re: Samsung UD65HU7200F smart tv - vertical lines on display
    Can't see your pictures?
    • bronstine
      • Jun 2015
      • 6
      Sorry - I went in to edit and there was no place to add attachments. I've contacted the administrator and as soon as I have that capability, I'll upload those photos.
      Thanks!
      Christine
        You can attach them to a new post. I'm not sure the admin, Topcat can help you much there.
        • bronstine
          • Jun 2015
          • 6
          Here's the pictures regarding the Samsung UD65HU7200F display issues.
          Thanks!
          Christine
          • freakaftr8
            • Oct 2012
            • 3743
            Wow is this out first curved 4k tv repair! !??
            How about any of the components on the top boards of the lcd screen? Bad solder connection? Try some freeze spray above the affected area
            To me it looks like a tab bonding issue but the rest of the screen affected may be a result of the affected area. Try just having the opposite side connected to the tcon. Is the grey shadow lines there still?
            • CapLeaker
              Leaking Member
              • 8221
              Wow! 18 months old and failed. Hmm... is that tab bond board on the bottom of the TV? If it is, ask your neighbour if he cleaned the TV screen lately.
                I would say the panel is failed. Sorry...
                • zomi
                  • Nov 2011
                  • 505
                  is it out of warranty
                  Thats very poor if its panel failure with no outside interference
                  • bronstine
                    • Jun 2015
                    • 6
                    Thank you all for your input. I will try freakaftr8's idea about attaching one side of the t-con board, then the other and see what happens.
                    By freeze spray, do you mean the compressed air cans that you can use to clean dust and other debris out of electronic components/keyboards, etc?
                    I'll also ask my neighbor about a recent cleaning.
                    Yes, the tab bond board is on the bottom.
                    Can the panel be replaced? I'm not totally clear on exactly what the parameters of that part are.
                    No warranty.
                    Thank you all for the input!
                    Christine
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      It looks like Costco in the USA sold this TV at $2179 after a $600 rebate.
                      http://www.costcoweekender.com/2015/...FXZA-hdtv.html
                      If this set was bought from Costco, they generally have a 2 year warranty on the TVs they sell.
                      I usually never buy extended warranties, but Costco has reasonable prices to extend the warranty up to 5 years.
                      --- begin sig file ---
                      --- end sig file ---
                        The "panel" is the 65 inch display, it is not practical to replace it (especially as it's curved) and is likely to cost more than a new TV. Only on certain specific TVs is it practical to replace the panel, in most cases it is not.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Wow, TV quality really has gone down the toilet these days, hasn't it?
                          If it is a tab bond issue, then it is gone I guess. I've fixed tab bond issues on calculators and microwave LCDs with my soldering iron (by just applying heat on the ribbon), but those generally have big traces. I don't think this would be possible here. But I suppose you could try before parting the TV out (if you chose to do that, of course... some people will watch it like that until it gets much worse).
                          • CapLeaker
                            Leaking Member
                            • 8221
                            Interesting... I never knew that Costco has warranty for a reasonable price like that.
                            • Falki
                              Colorful LCD Vertical Lines on Samsung ue55es8090
                              by Falki
                              Hello there, ive recently found an older 55inch Samsung SmartTV.
                              A similar issue has been posted as well but also with no actual response ...
                              08-12-2025, 04:19 AM
                            • Stanley1843
                              by Stanley1843
                              06-29-2024, 11:54 AM
                            • x_orange90_x
                              Samsung UN46C8000XFXZA vertical bars/horizontal lines
                              by x_orange90_x
                              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                              09-04-2023, 12:09 PM
                            • polaro
                              Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                              by polaro
                              Greetings,
                              I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                              08-27-2022, 08:46 AM
                            • Anonmis
                              Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                              by Anonmis
                              Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                              The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                              12-01-2023, 04:31 PM
