Sanyo and a polaroid shadows on the screen?
  • 102mm
    • Dec 2013
    • 181
    • us
    I thought i had two TV's repaired until i started playing a movie on them and noticed this weird shadow on the screens. seems to be in about the same spot on both. what causes this problem?
    The Sanyo is a DP32746 but i don't have access to the Polaroid but i know there are no similar parts between the two
    Craigslist Picks & Fixes
    2 ea - Samsung 52"
    Samsung 60"
    • 31291
    Re: Sanyo and a polaroid shadows on the screen?
    did you put them face-down on something that was not flat?
    • 102mm
      • Dec 2013
      • 181
      • us
      no they have been on upright the whole time.. you can still see the image on the screen in the dim area. it just looks bad..
      2 ea - Samsung 52"
      Samsung 60"
      • awyatt2
        • Feb 2012
        • 407
        • america
        did you have the panel out or has it been out? thoughts are maybe something between the diffuser and panel.
        • 102mm
          • Dec 2013
          • 181
          • us
          Haven't touched the panel, they have been in storage.. I just noticed that the dark spot on the Sanyo has some image retention in that spot.. it's almost similar to the failing AS15 chip on some tcons.. but that chip is not on this tcon..
          2 ea - Samsung 52"
          Samsung 60"
          • awyatt2
            • Feb 2012
            • 407
            • america
            maybe they got bumped in storage, strange they appear to be in the same spot.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • toddw65
              Sanyo DP5834 - Gray Screen
              by toddw65
              Hey All,
              I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
              Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
              Thanks,...
              10-31-2024, 10:37 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
