JVC LT-42EM59 no picture no sound
  • bayougrizz
    • Sep 2015
    • 23
    Re: JVC LT-42EM59 no picture no sound
    I apologize for my hiatus. Work has had me on the road weeks at a time. I am home now and am able to finish this up.
    I found two transformers. I unplugged the inverter board and on T9501 I measured the following:
    1-3 .1ohms
    4-5 .1ohms
    7-8 .1ohms
    9-12 .2ohms
    On T9201, I'm not sure what you want me to measure. I have attached snips from the manual depicting the transformers.
    Are we saying the power board is the issue?
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • Asraf Atb
      by Asraf Atb
      01-27-2025, 05:02 PM
    • Stephen
      A2991 Logic Board issue, 20volts 0 amps help!
      by Stephen
      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
      09-10-2025, 03:16 PM
