Vizio - XVT472SV
    Re: Vizio - XVT472SV
    If you check the resistance between the fuse on the T-CON board and one of these two MOSFET's leg/s, one of them should show <1 Ohms between the fuse and the legs of the MOSFET. Please verify which one, U1 or U33?
    • jasenpeters
      • Sep 2015
      • 53
      Guess who?
      U33
      If the diagram on the datasheet matches correctly, that would be the Drain Pins (5,6,7,8)
      are connected to that fuse. (I could be wrong)
        If it is the P-CH MOSFET then that will be correct that the fuse is connected to the Drain pin, the 12V is then should be connected to the Source, so check the DCV on the Source pin, it should have 12VDC there.
        Then also check the Gate pin and tell me what you have, all the readings are ref to GND.
        • jasenpeters
          • Sep 2015
          • 53
          U33 - 4953GM
          P-CH MOSFET Pin Voltages
          Pin 1 (Source 1) = 12.09
          Pin 2 (Gate 1) = 11.97
          Pin 3 (Source 2) = 12.09
          Pin 4 (Gate 2) = 11.97
          Pin 5 (Drain 2) = 0.25
          Pin 6 (Drain 2) = 0.25
          Pin 7 (Drain 1) = 0.25
          Pin 8 (Drain 1) = 0.25
          Are the Gates getting sufficient voltage to "turn on" the MOSFET's?
            The MOSFET is NOT being told to turn on, the Gate Voltage should be at least 1V less than the Source pin for it to start conducting, so the GATE pins should be 11VDC or LESS for it to be on.
            So the turn on command from the processor on the main board is not working. If you connect 500~1K resistor (1/4W will be fine) between the GND and the GATE pins then you should have 12V output at the Drain pins.
            Are pin 2 and pin 4 connected together?
            • jasenpeters
              • Sep 2015
              • 53
              On U33, pin 2 and 4 are connected via the land line. It's visible in the picture.
              If I connect the resistor as instructed and the Drains go to 12v, then what?
                If other functions of the main board are OK then you should see images on the screen since now you will have 12VDC feeding the T-con board for it to run.
                • jasenpeters
                  • Sep 2015
                  • 53
                  I haven't tested it yet with a resistor. But, if the Drains go to 12 and screen shows images, can I use the resistor as a "fix", or should I replace the Main Board? (Assuming I can't replace the processor, or is this a software issue?)
                  • jasenpeters
                    • Sep 2015
                    • 53
                    Ok, I tested it.
                    I'm getting an image now: "No Signal"
                    So, since the MOSFET stays on after jumping with the resistor, could I "rig" up a switch to turn on the MOSFET as a temporary solution?
                    • jasenpeters
                      • Sep 2015
                      • 53
                      Now I'm testing inputs, channels, sound and features.
                      BTW, this TV was being thrown out, it was not mine originally.
                        "So, since the MOSFET stays on after jumping with the resistor, could I "rig" up a switch to turn on the MOSFET as a temporary solution?" Yes, but you must turn on the switch A COUPLE SECONDS AFTER the power switch is activated.
                        What can be done too is to use the BL-ON signal to feed inverter (simple common Emitter) circuit to turn on the MOSFET.
                        • jasenpeters
                          • Sep 2015
                          • 53
                          Every thing seems to be working now.
                          Do you recommend replacing the Main Board as a permanent fix, or can this "ON" signal fail be further troubleshooted? Is it software, perhaps?
                            All other functions are OK so it is not likely to be firmware problem.
                            You can try tracing the Gate connections to see where it goes may be there are broken traces or something.
                            If the main board is cheap around $50 or so it may be worth it. You can try running it as is to see if something else will fail later on.
                            • jasenpeters
                              • Sep 2015
                              • 53
                              I turned if off for about 10 sec, and turned it back on.
                              I get an image still. Could this be from charged capacitors helping the processor send the signal or something?
                              I'll try turning it off for much longer and see. It may be an intermittent issue.
                              • jasenpeters
                                • Sep 2015
                                • 53
                                Anyone have a schematic to this one? or at least this Main Board?
                                It makes tracing easier
                                • jasenpeters
                                  • Sep 2015
                                  • 53
                                  I turned it off for over 24 hours, no power at all.
                                  Still comes on, behaving normally.
                                  All I can do is wait for it to misbehave again.
                                  Any comments on why it failed originally?
                                  I now have a new LCD TV upgrade (from a 36" tube boat anchor).
                                  Hopefully it will last for a good while.
                                  Thanks for all the help, I hope I can pay it forward.
                                    Just keep an eye on it.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      As you have probably gathered in the uk we cant click on your links as shopjimmys banned us from seeing them. we have to use a web proxy
                                      Hi Vinceroger69,
                                      Why did they do that?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        High fraud rates this thread has the emails i got back from them
                                        https://www.badcaps.net/forum/showth...cess+shopjimmy
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #40
                                          Hello vinceroger69
                                          Thanks for the update.
                                          Regards
                                          • Bugman1400
                                            Vizio E470VL got +5VSB, but no 12V
                                            by Bugman1400
                                            EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
                                            +5VSB= +5.09
                                            12V= +12.18
                                            PS_ON= +2.25
                                            I_ON/OFF= +3.27
                                            LAMP= +3.18
                                            DIM= +2.97
                                            Any more testing I can do on Main board or is it just a replacement?...
                                            09-04-2022, 09:19 AM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • прямо
                                            Viper22A 5VSB circuit
                                            by прямо
                                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                            01-13-2024, 07:05 PM
