I am working on a 40" dynex that never powered back on after a storm. There is no obviously visible problem on the boards but the transformer on the power supply is buzzing/ticking the plug that feeds the inverter board test good at 26v.
The larger plug that feeds to the main board however has some issues. There are two 12v and two 5v pins that when tested show low and erratic voltage that seems to correspond with the transformer ticking. The pin that is supposed to be 5v test 2.4v when first plugged in and it will work its way up to just above 5v and then there is a click and every thing goes dead. The 12v pin acts the same way but initially tests around 8v.
Is the transformer itself failing or could it be something else? Any help is greatly appreciated.
