Polaroid p40led13 backlight issue
  • steviewonder
    • Dec 2013
    • 183
    • england
    Hello once more,
    I was wondering if anyone has any ideas on this peculiar problem.
    this vestel set uses the 17ips20 power supply,and 17mb82s mainboard.
    At power on,the led backlights glow dimly,for a split second,the voltage to the backlights then dissapear.
    I have removed the screen for a nosey,all led's illuminate very briefly,and was suspecting one of the lighting strips to be faulty,apparently not the case.
    There is 5v bl-on appearing at pin 3 on psu,and 3.3v on the dimming pin,so this seems to rule out the motherboard.A quick check on the psu revealed nothing obvious,so fitted another identical psu....and.....exactly the same...
    Very puzzling...unless the other power supply could be faulty in the same way?
    pics of boards to follow.
    best wishes for now then,
    steve
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Polaroid p40led13 backlight issue
    Common issue is the led backlights themselves failing what panel does this use ?
    • steviewonder
      • Dec 2013
      • 183
      • england
      The panel is ves400unds-00,
      My first thoughts were the backlamps,however all appear to work,albeit briefly.(I stripped the screen down to see).
      Had a panasonic last week with a similar issue, 9 leds fried...only 18 months old.
      A curious issue,not helped by a rather vague service manual for the psu...
      • CapLeaker
        Leaking Member
        • 7982
        measure the voltage outputs on the led driver with the backlights connected. Describe exactly what they are doing and if there is a difference from one string to the other.
          Yes the 17IPS20 generates 24V which is then boosted to about 60V for backlights (maybe different for 40" screen)
          So check the boosted supply is present and stable. If it is low, it may cause this fault, although I would expect no light from the LEDs if it was very low.
          • steviewonder
            • Dec 2013
            • 183
            • england
            hello once more,Thanks for the suggestions so far.
            it would appear that the strings are connected in series internally,as there are only two wires leaving the screen,the problem with measuring the voltage is it rises and falls so quickly that my meter (Fluke 12) hasn't the time to respond,there's 117v available to be switched,so i would imagine that's the voltage reached.It did cross my mind that even though all led's are lighting,is it possible one,or more is drawing excessive current,hence shutting the supply to the lamps down?.....mmmm
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Its very possible best bet would be to take the panel apart and see if any of the leds done light the return voltage sounds right so im suspecting an led.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Also I have led strips for that panel I had to service a toshiba with them bulbs same issue.
                • CapLeaker
                  Leaking Member
                  • 7982
                  try the min / max settings on the fluke
                    It is also possible that one strip is open circuit, and you are seeing the LED power supply hit the over-voltage threshold with some strips lighting ok then it is shutting down because the rest are not ok.
                    • steviewonder
                      • Dec 2013
                      • 183
                      • england
                      hello once more ,
                      well the min/max results seem inconclusive,just get greeted with OL on the fluke,possibly down to the drive waveform?.mmm.Anyway will strip the panel out once more,and this time remove the strips for a study,but as i said earlier,EVERY led on each strip illuminated briefly.
                      With a second psu fitted,and the same issue....so will report back soon with what i find!
                        Make sure you set the RANGE on the fluke as the autoranging may take time. Lock it in the 600V range for example.
                        An oscilloscope can also help...
                        • steviewonder
                          • Dec 2013
                          • 183
                          • england
                          Thanks Tom,
                          some progress..removed the panel once more,and it seems i missed the fact just one led does not illuminate,easily missed as the lamps only illuminate for a matter of milliseconds...just going to replace that and see what happens..Give me a bush tv22 or Decca bradford any day over this rubbish!.will report back,Ahh yes tom,forgot about the range settings,Long time since used on min/max and range settings!
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Knew it ! Ultra common issue failing leds do you know how to replace the led ?
                            • steviewonder
                              • Dec 2013
                              • 183
                              • england
                              yes reecyburger!
                              not much of a challenge,it's the stupidity of me in the first place really for not 10x checking....DOH!..incidentally,these strips are manufactured by the same company that LG use in the lc420DUE panel,so expect some panasoncs failing soon! (mentioned this earlier)
                              a pic paints a thousand words...until the next lamp fails....I mean,really? ONE led out of 45 fails and no go at all.....gawd...but thanks for the input to tom66,capleaker and you yourself...Hopefully this challenge may help someone else viewing this thread at a later point!
                              • steviewonder
                                • Dec 2013
                                • 183
                                • england
                                seems the pic has failed to upload..
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Ohh yes I have done a Panny with an Lg panel. Yes only 1 led and all out wired like christmas lights each led has to break over to power the next and complete the circuit if that fails all out trash design really and very problematic and its not just with full array sets like this the edge lit ones are just as bad. I just hate led lcd tvs in general I could rant all day about them I will always stick with plasma haha. Let us know how it goes buddy
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Any update ?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Update ?
                                      • csocsoi
                                        • Sep 2016
                                        • Hungary
                                        Hello, so this board generates about 60 V at a 40" screen? I have a 40'' Philips with this board and with no backlight, so it means if the output is about 60V that I have some failed LED bulbs?
                                        thank you
                                        • Cornito
                                          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                          by Cornito
                                          Hello Team,
                                          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                          08-08-2024, 08:09 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • Cornito
                                          TCL 65C715 backlight issue
                                          by Cornito
                                          Hello team,
                                          I'm back with another topic.
                                          It's a 65C715 TCL tv with backlight issue.
                                          But the problem is a bit strange.
                                          When I took this tv from the marketplace backlight didn't work but picture was ok.
                                          Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                                          Putting all back together the tv worked fine for weeks. => Contact issue??
                                          Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                                          06-09-2024, 02:24 AM
                                        • shellybelly
                                          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                          by shellybelly
                                          Back Story
                                          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                          08-27-2023, 10:40 PM
                                        • Riananyaina
                                          MacBook A1708 820-00840-A backlight issue
                                          by Riananyaina
                                          Hello Everyone ,
                                          today I'm coming to you regarding my issue which is no Backlight .
                                          I have image on my screen but no light .
                                          The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                          First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                          Please find below few informations which can help for the analysis...
                                          04-24-2023, 05:03 AM
