LG LED TV Diffuser
  • tech2014
    • Aug 2014
    • 807
    LG LED TV Diffuser
    I took apart this LED tv to test the LED strips and now I can't remember what order these parts go in. There are 3 sheets, one looks reflective and metallic, the other 2 are plastic. See pic below. I need to know which way these go in.
  • flocko
    • Nov 2012
    • 1121
    Re: LG LED TV Diffuser
    I will be striping a 42LA660V later this week. I know it does not have the same type back light, yours being multi strip and the LA model being edge- lite, but would think the sheet placement would be the same maybe?. so if no one comes up with a better plan I will tell you when i strip the set Flocko
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Normally its the thick plastic at the start thats all I can say haha Doh !
      • tech2014
        • Aug 2014
        • 807
        I got it figured out and put back together.
        • daffsters
          • Feb 2018
          • 5
          I have the white spot issue where the plastic reflector has fallen off of the LED. Since my TV is out of warranty, I disassembled it to glue the fallen reflectors back into place. Unfortunately, I did not note what order and orientation the hard plastic and 3 flexible diffuser sheets go in for re-assembly. What is the correct order? I know the hard plastic goes first, but does the smooth side or the textured side face the reflectors? After that, which sheets go in which order? Thank you!
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • V3dran
            Diffuser/LPG for UE50NU7022KXXH
            by V3dran
            I'm trying to repair a UE50NU7022KXXH with a cracked diffuser/lpg and now also with burned leds
            There are 4/5 white spots on the bottom that are not visible since the left side is dark now so I want to change the diffuser/lpg
            Looking the samsung spare parts, I see that there is a DIFFUSER PLATE and a LPG so I'm wondering what is really broken?
            https://www.samsungparts.eu/samsung-...n61-15659a.htm DIFFUSER PLATE 1125x625x2,5mm
            https://www.samsungparts.eu/samsung-...n61-15661a.htm LPG 1101x619x2,7mm...
            06-26-2025, 01:54 AM
          • geo86
            Plastic stand offs for backlight diffuser
            by geo86
            Does anyone know where to buy plastic stand offs for backlight diffuser, mainly for Vestel TVs?
            They are extremely brittle and almost always they break into pieces.
            I looked on internet but little success.
            Thank you!...
            08-22-2022, 12:40 AM
          • Kemer
            Led status indicator light transfer plastic
            by Kemer
            Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
            There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
            The plastic piece doesn't appear to be broken.
            1. What are your suggestions for resolving this issue?
            2. Is the plastic piece made of special ma...
            08-19-2025, 07:02 PM
          • David Stroe
            AOC CQ27G2U/BK - in need of data sheets
            by David Stroe
            I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
            I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
            Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
            Main Board: 715G9500-M0C-B00-005K
            T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
            If someone could please provide any of these data sheets, it would be awesome....
            05-31-2025, 11:12 AM
