LG LED TV Diffuser
    LG LED TV Diffuser
    I took apart this LED tv to test the LED strips and now I can't remember what order these parts go in. There are 3 sheets, one looks reflective and metallic, the other 2 are plastic. See pic below. I need to know which way these go in.
    Re: LG LED TV Diffuser
    I will be striping a 42LA660V later this week. I know it does not have the same type back light, yours being multi strip and the LA model being edge- lite, but would think the sheet placement would be the same maybe?. so if no one comes up with a better plan I will tell you when i strip the set Flocko
      Normally its the thick plastic at the start thats all I can say haha Doh !
        I got it figured out and put back together.
          I have the white spot issue where the plastic reflector has fallen off of the LED. Since my TV is out of warranty, I disassembled it to glue the fallen reflectors back into place. Unfortunately, I did not note what order and orientation the hard plastic and 3 flexible diffuser sheets go in for re-assembly. What is the correct order? I know the hard plastic goes first, but does the smooth side or the textured side face the reflectors? After that, which sheets go in which order? Thank you!
