Bush IDLCD32TV07HD with Tcon LC370WX4-SLA1 no picture
  • FIXITNOW
    • Jun 2008
    • 128
    Beko main board XLX190R-4
    PSU FSP312-2m01
    Inverter LC370WX4
    Tcon LC370WX4-SLA1
    Fault set has sound and backlights are on and nice and white
    But no picture caps on invert were swollen so replaced
    Fuse on tcon was open replaced now have 12v both sides but still no picture
    Anyone repaired one of these Tcons or have circuit
    It has an TPS65161 buck boast chip fitted and VDD seems to be at 0v which is from transistor Q5 marked L7x3b (note the x has a line under it) it does nor read correct and is the only one on the board
    anyone know this device ?
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Bush IDLCD32TV07HD with Tcon LC370WX4-SLA1 no picture
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • flocko
      • Nov 2012
      • 1121
      • uk
      Your set has the LG panel fitted,The board number of the T.Con is 6870C-0158A not LC370WX4-SLA1 this is the panel match number. And the part number is screen printed in red or white and this has to match with any replacement, confusing but that how to get the right T.con. I would not waste to much time trying to fix the board as they are out there and no money. hope this helps Flocko
      • FIXITNOW
        • Jun 2008
        • 128
        thanks for the help the silkscreen printed number is in black
        and
        is
        4A108D 1219A1
        having trouble finding this one but will keep looking. But was hoping I could replace Q5 as a quick start but can not Id it if that did not cure was going to try the TPS65161 chip
        • flocko
          • Nov 2012
          • 1121
          • uk
          The full part number of your board is 6871L-1219A ? (were did the 6871L number come from ?thats there board pre fix number) Thats how confusing LG/Philips are with part numbers, but as long as it shows 1219A screen printed in red or white thats the board you need. I have checked for you and there are no subs on this board . But at least you know what your looking for. happy hunting
          • FIXITNOW
            • Jun 2008
            • 128
            thanks for all your help I will keep hunting
            if I can id the transistor will do.I have some different LG/Philips tcon from early pre HD TV's so will se if any have one fitted
            all the best Vince
            • flocko
              • Nov 2012
              • 1121
              • uk
              Just looked on ebay one on there item number:261041658776
              • Fly_Among_Stars
                VIZIO E70-E3 Half picture with half TCON
                by Fly_Among_Stars
                I have a VIZIO E70-E3.
                Symptoms: Black screen, no picture, but LED backlights are working.
                I probed the power board and voltages are as listed on the board.
                Main board appears fine, too.
                I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                There are two separate ribbon cables feeding the LCD.
                If both are connected, the screen is black.
                If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                04-24-2023, 08:20 PM
              • iglitare
                Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                by iglitare
                i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                Backlight seems to work, Sound (Setup menu after reset) works.
                If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                With my small knowledge i would think at least the cables are good.
                Can this happen because of a bad tcon board?
                Or is it always a bad/shorted...
                09-04-2025, 07:13 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • shelby5041
                Samsung LCD TV no picture backlight on no 12v at tcon
                by shelby5041
                hi
                i have a samsung lcd tv
                it powers on with sound and backlight but no picture
                all voltages from PS are good 12v 3.3v and 5v
                whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                no 12v at the tcon fuse
                i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                the odds of having 2...
                10-08-2021, 08:21 AM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
