hisense f42k20e no backlight
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I got this set the led lights red when I press power it goes blue but no backlights. all the voltages on the power supply are correct. the only thing im trying to determine if it is bad led strip or main? the bl/dim have 3.3 and 5v and then this lines going to the backlights the top + has 132.00v and the other 2nd + has none
    Re: hisense f42k20e no backlight
    How about the pictures of the whole backside of the TV and the whole boards?
    Turn the TV off then have the probe attached to the TOP + (PIN 1) keep an eye on the DCV meter when turn on the TV to see if the Voltage goes higher than 132VDC.
    Then do the same again WITHOUT the LED connector in place, report the reading.
    It looks like the two LED strings are connected in series to form one big string.
    • mattstolte
      • Dec 2013
      • 612
      • usa
      yes bud will get some tomorrow thanks. is there suppose to be no voltage on the bottom 2+ ?
        If the LED strings are connected in series, so if the first string is open then the other strings will not have any current flow through them to develop the Voltage drops on the other LED string.
        Looking at you board, I would say it only has two LED strings and they are connected in series.
        I expect the DCV on the connector to jump to > 200VDC when you first turn on the TV and then drops down to lower Voltage.
        • mattstolte
          • Dec 2013
          • 612
          • usa
          BUD the voltages do not change
            So it shows 132VDC when the power switch is activated and it did not jump higher that that at all?
            BTW, if you have the LED connector hooked back up and you get no DCV at all on the 2+ pin, that will indicate that the +1 string has open circuit.
            • mattstolte
              • Dec 2013
              • 612
              • usa
              Yes none are line 2
              • ojmc
                Hisense 65H6570G - Color inverted after replacing LED backlight
                by ojmc
                Background:
                • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                • I replaced all 6 of the backlight LED strips with these replacements: amazon
                • The TV worked again perfectly for ~2 weeks.
                • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                10-17-2024, 02:29 PM
              • Mschrenkz@gmail.com
                Hisense 60R6E - No backlight - stuck in boot loop
                by Mschrenkz@gmail.com
                I joined hoping I'll be able to verify which component I need to replace on my Hisense 60R6E. When I plug it in the red light comes on and stays on for several seconds then blinks off and then on again. There is no back light but I can see the logo screen "Hisense Roku" (using the flashlight method) come on while the red light is off. Then it dissapears and the red light is constant again. This cycle keeps repeating. I tried pressing the reset button and it has absolutely no impact. Even held it in for 30 seconds also tried holding the power button in with the TV unplugged - nothing...
                05-09-2023, 08:53 AM
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • frannyjunk
                Hisense 40H4F no backlight but turns off after splash screen
                by frannyjunk
                So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                TIA.
                09-24-2025, 10:59 AM
