Vizio SV370XVT White Screen - then clears up
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I was just given a Vizio SV370XVT. When I turn it on, the screen is white with multiple variations on it. Sound is good. As it warms up, the video will start to appear to the point of working and looking perfectly after 10-15 minutes. So it seems to get better as it heats up. I was wondering if anyone has encountered this problem and any suggestions where to start. Sounds like a problem with the T-con board but thought I would ask before tearing it apart.
    any information is much appreciated.
    Thanks!
    Joe
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Vizio SV370XVT White Screen - then clears up
    try heating / cooling the t-con board
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Clean and re-seat all cable connections from Main Board to T-Con and from T-Con to Panel. I usually clean them with an eraser and moisten then with a very little WD-40.
      • augiedoggy
        • Aug 2016
        • 62
        • united states
        I have 3 of the same model tv and a 32" version of the same series tv with this same issue.. a few blue horizonatal lines at the very to and the screen slowly fades to white.. anyone ever figure it out? Its not loose or dirty ribbon cables.
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • EazyBone
          Sharp LC-65Q620U White Screen
          by EazyBone
          Another TV topic!!
          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
          08-21-2024, 12:56 PM
        • hcinne
          Dell G15 ryzen edition black screen 2 amber 1 white
          by hcinne
          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
          07-23-2024, 07:56 AM
