Sharp Aquos LC-60LE blank white screen only
  • voltron88x
    • Jun 2015
    • 21
    Hey guys, have a Sharp Aquos Quattron LC-60LE832U that powers on fine, but only displays a blank white screen (no blinking front panel light). I can hit the menu/input buttons and the screen brightness undulates brighter or darker (looks like it's trying to do something), but nothing actually displays. There are some static horizontal lines present as well. Other symptom includes a slowly blinking D3303 led on the main board (DKEYMF733FM01S).
    I've searched around but can't really find anything specific to this. I've been checking out this thread, but again symptoms are a bit different.
    Any thoughts? Thanks!
    ("swirls" on tv picture are from camera)
    Re: Sharp Aquos LC-60LE blank white screen only
    Quick test, try having on flat ribbon cable between the LCD panel and the T-CON connected one at a time to see what you get.
    • voltron88x
      • Jun 2015
      • 21
      Yes I tried that and it just splits the screen in half...though one half is just white with no horizontal lines - the other half with the lines.
      • voltron88x
        • Jun 2015
        • 21
        This is what it looks like with only one ribbon cable connected.
        • CapLeaker
          Leaking Member
          • 8119
          what happens if you connect the one you disconnected and disconnect the other one?
          • voltron88x
            • Jun 2015
            • 21
            Same, just alternated.
            • CapLeaker
              Leaking Member
              • 8119
              Can you get your hands on to an oscilloscope?
              • voltron88x
                • Jun 2015
                • 21
                Possibly. What would be the plan?
                • CapLeaker
                  Leaking Member
                  • 8119
                  get it and check the LVDS signal coming out of the main board. Turn the menu on and off all the time and signal should change on the oscilloscope. That makes sure you have video coming out of the main board and you know 100% you got a T-Con problem. You also can check the T-Con output the same way.
                  • CapLeaker
                    Leaking Member
                    • 8119
                    A second thought: since you get a heartbeat (slow blinking LED on the main board), the video output should be working on the main board.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Bad T-Con Board is my guess....
                      • voltron88x
                        • Jun 2015
                        • 21
                        Replaced the T-Con board and partial success!
                        Getting an odd vertical line issue on one side now...any thoughts?
                        • voltron88x
                          • Jun 2015
                          • 21
                          Better pictures. Looks like it's the left-inner 25%
                          • CapLeaker
                            Leaking Member
                            • 8119
                            defective tab
                            • voltron88x
                              • Jun 2015
                              • 21
                              defective tab
                              Thanks. I suppose you're referring to the ribbon cable connectors?
                              • voltron88x
                                • Jun 2015
                                • 21
                                Ah nevermind, figured out what you meant.
                                • EazyBone
                                  Sharp LC-65Q620U White Screen
                                  by EazyBone
                                  Another TV topic!!
                                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                  08-21-2024, 12:56 PM
                                • Chrissygizmo
                                  Panasonic TX-48CX350B backlights but white screen , blank screen
                                  by Chrissygizmo
                                  Hi all, I’ve got a problem I hope someone can help me fixi.
                                  I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                  01-11-2025, 03:18 PM
                                • thesharpfella
                                  Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                  by thesharpfella
                                  Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                  07-23-2024, 10:37 AM
                                • harp
                                  White screen repairs
                                  by harp
                                  To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                  Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                  On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                  05-13-2024, 03:43 AM
                                • sefoster
                                  Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                  by sefoster
                                  I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                  11-20-2022, 09:29 AM
