samsung un46d6000 no picture
    Re: samsung un46d6000 no picture
    What is the power supply board P/N? BN44-00423A?
    If you at the board, there will Voltage chart printed on the board to tell you what the LED drive Voltage will be with load.
    Test steps: no main board connected to the power supply board
    1) Put LED connector back in place.
    2) Keep Black probe on the chassis, Red probe on Top 1 +
    3) Power up up the board while keeping your eyes on the mete to see how high the Voltage jumps up to before it settle down 10 seconds later, then remove power from the board.
    4) Move red probe to Top 2 + and repeat step 3.
    5) Do the same on Top 1 - and Top 2 -.
    6) Report the results.
    More likely to have open circuit in the LED string, LED strips are connected in series to form one large LED string.
    Your bench power supply will not have enough Voltage to drive this large LED string.
    LED tester: You can get LED tester similar to this for around $30 on EBAY.
    https://www.shopjimmy.com/sid-gj2c-l...ght-tester.htm
    • jasenpeters
      • Sep 2015
      • 53
      "What is the power supply board P/N? BN44-00423A?"
      Yes, so I assume, the Power Board has a red dot next to:
      PD46A1_BSM (BN44-00423A)
      See Pic below:
      I'll have test results soon...
      • jasenpeters
        • Sep 2015
        • 53
        -- Voltages at Power Board Connector: CNL802 to LED Lights
        Code:
        Pin Label  Voltage (DC) to GND
                  Pwr On
               1st Peak 2nd Peak 3rd Peak
         7  TOP 2-  0.70    0.05
         5  TOP 2+  ~210    ~21   ~1.5
         3  TOP 1-  ~210    ~21   ~1.5
         1  TOP 1+  ~300    ~255
        After the final peak, the voltages repeat.
        All voltages are Positive with respect to GND
        ~ means approximately
        I'm using a Fluke 73III Multimeter
          You have open circuit in the LED string, IE. LED failed open circuit, open circuit due to bad connector, open circuit wiring.
          • jasenpeters
            • Sep 2015
            • 53
            Roger that...
            Ok, I'll take the rest of the body apart and get to the LED strip(s)...
            And work from there...
            I suspect that if they are in series, one or more LED's are bad.
            I doubt the actual connector to the Power Board or the wiring from the
            Power Board to the LED strip, but I'll check.
            Sounds good?
            • jasenpeters
              • Sep 2015
              • 53
              I tested both Right and Left LED strips.
              One of the LED panels is bad, as predicted.
              Of, 36 LED, most were shorted, according to the Fluke continuity test.
              The other panel, the good one, all LED's were tested.
              From measurements of voltage and brightness of a single LED Light,
              it seems that 2-2.5 volts can have a single LED light pretty bright.
              That would be about 70-90 VDC or more to light 36 pairs in series.
              For a strip, there is 2 parallel lines of 36 LED's in series.
              Let me know if this makes sense.
              Is it possible to power up the power board and have the "good" strip plugged in and light up as normal?
              Or, do I have to have both strips (both being good) plugged in, for anything to light up?
              Bad Strip: 2011SVS46_5K6K_H1B__1CH_PV_LEFT72
              shopjimmy does not have one, any suggestions?
              Thanks for any advice
                All the LED's are connected in series so what ever you do, all the LED strings have to be good LED strings to have all of them lighted up, the Vf of the LED will be around 3V at rated current, they typically drive these LED at or above max rated current so they failed.
                When you get new strips make sure to turn down the backlights to as low as possible.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4536
                  • Italy - Milan
                  #28
                  To troubleshoot is the mainboard...
                    09-07-2024, 05:50 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Asraf Atb
                    by Asraf Atb
                    01-27-2025, 05:02 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • JSin21
                    Compatibility of main boards between different variations of samsung MU6100
                    by JSin21
                    Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                    I have Samsung Smart TV UA65MU6100WXXY version DA01
                    Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                    11-27-2023, 04:54 AM
