BUSH Bpdp42hd colour issue
  • sordids999
    • May 2013
    • 2161
    hello guys
    got this issue at the moment where the right hand side of the screen is showing distorted colours i have uploaded picture of the fault as well
    VScan 196 Volts
    VS 204 Volts
    VE 100 Volts
    VA 54 Volts
    if anyone can help
    thankyou
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: BUSH Bpdp42hd colour issue
    It may be that little Timing Bd in the middle or the board at the bottom corresponding to the distorted picture.
    • sordids999
      • May 2013
      • 2161
      Do you mean the control board ?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes
        • sordids999
          • May 2013
          • 2161
          I will try a replacement control board i have tested voltages all seem ok and i cant find no shorts etc on the Ysus/Zsus
          so ill update this thread soon
          • sordids999
            • May 2013
            • 2161
            Well tried a replacement control board still the same any ideas ??
            • mmartell
              • Oct 2013
              • 3189
              Do your voltave readings match the sticker on the panel ? Looks to me like you have a problem on your z sustain board - I would start checking it for blown fets or burnt resistors.
              • sordids999
                • May 2013
                • 2161
                Thats the thing ive checked fets for shorts nothing and all voltages match up with the panel sticker
                • sordids999
                  • May 2013
                  • 2161
                  more pictures to the right of the screen i have a blotches of colour
                  • sordids999
                    • May 2013
                    • 2161
                    im also noticing there is a slight text which i cant read or show via picture which is showing on the screen that never goes away as if its image burn ?
                    • mmartell
                      • Oct 2013
                      • 3189
                      That as well is indicative of a bad zsus or at least improper bias setting. If you adjust the bias pot does the voltage and or picture change too ?
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        Bad locallised Mal-Discharge, Its a pretty old/worn out (Samsung) panel I guess, seen a few exactly like it, in the 42C450, with 15+ K hours on 'em.
                        (For some odd reason--Its always the Right hand side of screen--Production error/tolerance I expect)
                        Sometimes careful potching with SET-Up and SET_Dn as well as upping the Vs by around 10V can help....
                        Only permanent cure is panel replacement--Which aint viable....
                        TELEFIX
                        • u666sa
                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                          by u666sa
                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                          Platform: ipa32 la-m024p rev 1b
                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                          I found a short on the other side:
                          10-04-2025, 05:03 PM
                        • rounin
                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                          by rounin
                          🛠 Original Issue
                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                          04-19-2025, 01:18 AM
                        • ugamazing
                          by ugamazing
                          12-17-2024, 07:05 PM
                        • shahnld
                          Lenovo legion 5 pro startup issue
                          by shahnld
                          Good day Experts
                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                          08-24-2025, 12:31 PM
                        • ahmarzo
                          Acer laptop battery draining issue
                          by ahmarzo
                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                          08-02-2025, 06:39 AM
