Toshiba 32w3453d no video or audio backlight on
  • london-freddie
    • May 2015
    • 472
    Re: Toshiba 32w3453d no video or audio backlight on
    didn't know how to check on this board there are no pin markings on board with voltages etc
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      And have you ordered the right psu for this set you cant just stick any 17ips11 in there ?
      • london-freddie
        • May 2015
        • 472
        same numbers on sticker
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Thats good hopefully it sorts if not probably mainboard.
          • london-freddie
            • May 2015
            • 472
            ok fitted replacement powerboard still the same backlight on no video or audio, so have changed mainboard same numbers on sticker same no video or audio and now changed powerboard again same numbers on sticker.
            now I have not got a clue can a panel fault stop it firing up or have I got another faulty mainboard
            • london-freddie
              • May 2015
              • 472
              anyone anymore ideas on this one
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                i wonder if you could get a scart lead and connect to your non working set and then connect the other end of the scart to a working tv if you get a picture through the working tv screen would this prove a panel fault on the non working tv?
                • lorins_core
                  BlackSmith
                  • Dec 2012
                  • 551
                  • Philippines
                  #28
                  Originally posted by ReeceyBurger123
                  You cant do that on these shorting the epprom will kill it totally. I honestly hate the tvs with a passion you have to options:
                  Replace and reflash the epprom/flash chip
                  Replace the mainboard with EXACT MATCH
                  Yes i agree to this Answer...
                  • lorins_core
                    BlackSmith
                    • Dec 2012
                    • 551
                    • Philippines
                    #29
                    Originally posted by Hamie
                    Pictures needed.
                    I take it the TV doesnt have a t-con.
                    If not, going by description sounds like main board fault.
                    Also This Advice I Agree...
                    • london-freddie
                      • May 2015
                      • 472
                      ok will try this shortly
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4970
                        • New Zealand
                        #31
                        I found a schematic for the mainboard. It shows the power connector pinout so you should be able to check the voltages from that. See page 5, left side.
                        Also you can check the secondary rails from the mainboard's onboard regulators.
                        I don't know if that schematic will be exact, but should be a good place to start.
                        -David VanHorn
                        • london-freddie
                          • May 2015
                          • 472
                          connected scart to working tv other end of scart to this non working tv no picture on non working set
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4970
                            • New Zealand
                            #33
                            Try it the other way around, see if you can get video output through SCART from the non-working set to display on the working one.
                            -David VanHorn
                            • london-freddie
                              • May 2015
                              • 472
                              nothing just tried using hdmi cable as well between the two sets
                              • london-freddie
                                • May 2015
                                • 472
                                now tried every combination I can think of using scart and hdmi between the two sets no output from Toshiba to working tv no input from working tv displaying on toshiba
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  ive manged to get that idea working a few times scart to scart on working and problem tvs basically were trying to find if your power supply and mainboard on the faulty tv is working to a point ive just tried this on two set i have here one has a smashed screen i have the aeriel plug in the non working set (connected together via a scart lead) then flick through the source menu on the working tv and its picked up the picture/sound from the smashed screen set im not sure this works on all tvs though and i suppose if your non working set is on dtv source with sound on etc so may have to go through source menu on both tvs.
                                  • london-freddie
                                    • May 2015
                                    • 472
                                    i am thinking this replacement mainboard is also faulty
                                    • london-freddie
                                      • May 2015
                                      • 472
                                      i think i understand what you are saying here, i have just tried connecting a digital tv box into faulty set using hdmi and sending it out to the working set, still no go,
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        the ribbon cable going too the board on the bottom of the set i wonder if theres a surface mounted fuse by the ribbon connector but yes as you say i guess if its a common issue the replacement main board can be bad too was it a exact match all sticker numbers etc also theres a panel sticker on the chassis of the tv do these have to match the mainboard somehow too?
                                        • london-freddie
                                          • May 2015
                                          • 472
                                          no tcon board
                                            09-06-2024, 05:27 AM
                                          • samson7point1@yahoo.com
                                            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                            by samson7point1@yahoo.com
                                            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                            The player processes the audio signal using two different reference frequencies. The "R"...
                                            04-30-2024, 11:22 AM
                                          • SolarFlare
                                            Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                                            by SolarFlare
                                            My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                                            The TCON board has the following Chips -
                                            Samsung VTU63A0
                                            RT6939 - 2nos.
                                            and all these chips are getting real hot within a minute, I dont know if this is normal....
                                            06-26-2022, 08:58 AM
                                          • Max514
                                            Samsung UN55H8000 sound but no backlight no video
                                            by Max514
                                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                            • Unplugging the main board cable at the power supply >>> backlights came on.
                                            • BLU_ON signal from the
                                            04-14-2022, 10:34 AM
                                            Toshiba Satellite Pro A200-1KQ Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro A200-1KQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1KQ boardview and A200-1KQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
