Replace SMT LEDs on your backlights!!!!
  • supertype
    • May 2013
    • 14
    I have seen this problem a lot so i made a video on how to replace the burned/shorted LEDs from your backlights.
    https://youtu.be/LqaeqCSDWFQ
    Please let me know if this worked for you!
  • mmartell
    • Oct 2013
    • 3189
    Re: Replace SMT LEDs on your backlights!!!!
    That is pure genius. Thanks for sharing.
      Useful trick!
      This will work for certain types of strip which use a metal core PCB as a heatsink and for LEDs which have pads under the device. The thermal pad on the bottom of the LED is likely to cause problems with hot air removal. If the LED did not have a thermal pad it should be easier to remove with hot air.
      A high power soldering iron, at least 60 watts, will be useful if attempting to remove these. It's probably not as critical that it is temperature regulated provided you don't burn the PCB itself.
      • supertype
        • May 2013
        • 14
        Originally posted by tom66
        Useful trick!
        I would recommend a little practice with a old back-light before trying on a fixable unit
        from my experance i don't see the sinked LEDs on normal PCB as much as on the ALU strips
        i do have a nicer hakko head unit for my iron
        Thanks for all the feedback guys.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Nice one
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
          • ktmmotocross
            Thinkbook 15 G2 ITL no ALW voltages after replace burned USB-C contoller
            by ktmmotocross
            Hello.
            Have this Thinkbook 15 G2 ITL that have burned USB-C controller U24. After replace i have main VIN voltage, but no ALW voltage. PU301 have VIN but no LDO and other voltages. i relace ic but still the same.
            ic is SY8386. LDO should be working right after vin ?
            board code is LA-K052P
            any hint?
            12-26-2024, 01:53 AM
          • unimatrix93
            Which resistor should I remove/replace to decrease current to backlight leds?
            by unimatrix93
            Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
            However I need some help identifying the resistor I need to replace to achieve this.
            Thank you!
            11-29-2024, 05:05 AM
          • Pipolups
            Corsair K70 LUX RGB dying LEDs
            by Pipolups
            Hi there !
            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
            10-08-2024, 11:58 AM
          • lmcancu
            RCA RLDED 4331B: 43 inch LED TV: Backlight issue
            by lmcancu
            Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
            Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
            Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
            Instead of putting it back together I decided to replace...
            04-01-2023, 01:11 PM
