Capacitor ID
  • humble
    Tinker
    • Aug 2014
    • 12
    Capacitor ID
    Hello All,
    My remote is not working but all the buttons on the TV work OK.
    The remote's I.R. output passes the camera test.
    I have renewed the IR receiver even though the old one checked out ok.
    The infrared detector sensor board has an SMD 2012 (metric) capacitor "C1" which I believe to be faulty. Please see attachments.
    With the I.R. sensor removed no other elements are involved & C1 capacitance reads O.L. and it shows 1.9 ohms resistance.
    The cap has no value on it & after many hours I have been unable to find a schematic with its value.
    It bridges between the board's 5v power supply & ground.
    The TV is a Toshiba 32AV500A. (Australian release)
    Can I remove C1 for good with no long term ill effects?
    Is there a generic value that I might substitute?
    Or if someone can point me to that particular C1 value I would appreciate it very much.
  • CapLeaker
    Leaking Member
    • 8344
    Re: Capacitor ID
    Either a 0.33uF (input) or a 0.1uF (output) depending.
    • humble
      Tinker
      • Aug 2014
      • 12
      Re: Capacitor ID
      Thanks for your reply CapLeaker.
      I am not sure of the significance of input & output.
      The 5vDC to C1 is input supply from the power board via pin 1 of the the 6 pin socket on the IR board & through R5.
        • 31265
        Re: Capacitor ID
        that cap is pretty big, i suspect it's more like 10uf!
        • SteveNielsen
          Retired Tech
          • 2327
          Re: Capacitor ID
          The 5v would be the input, so he's saying try a 0.33uF cap there and a 0.1uF on the other. The one missing in the pic is the output.
          Many IR detector circuits don't use caps at all, I think you could try it without C2 and see if it functions.
          • humble
            Tinker
            • Aug 2014
            • 12
            Re: Capacitor ID
            Stj, The photo does make it look big.
            It measures 2,0mm long & 1.3mm wide (2012 metric form)
            Very general specs give those ceramic SMD caps 1nF~100uF if you call it light brown or 10nF~1uF if you call it medium brown. The adjacent resistors are dark brown.
            Steve until your post I did not realise that C2 was missing! The gap measured 0.2 nF
            I will try to buy 0.33uF & 0.1uF SMD tomorrow (in backwoods Adelaide ha ha)
            Failing that I may have to substitute a wired alternative.
            Thank you everybody for your replies.
            • SteveNielsen
              Retired Tech
              • 2327
              Re: Capacitor ID
              I misunderstood. I saw C2 missing and thought you'd removed it and it was the bad one. My brain fart, sorry. Anyway, either way, try it without C1 and see if it works if you want to. I don't think it will do any damage to try. I believe it is there to help smooth transient switching currents and the circuit may basically function without it.
              • humble
                Tinker
                • Aug 2014
                • 12
                Re: Capacitor ID
                I like your workaround. Try running without the shorted C1 & the missing C2. Suck it & see. Thank you.
                • jetadm123
                  • 2169
                  Re: Capacitor ID
                  Any chance that IR detector has a part number? If yes, then you can can look up the datasheet for it. Usually the manufacturer will include a circuit for setting up that detector.
                  • humble
                    Tinker
                    • Aug 2014
                    • 12
                    Re: Capacitor ID
                    Yes, good thought.
                    Original IR detector is
                    5B89
                    53A
                    I had Googled it but got no hits.
                    Not having brand name didn't help. However the replacement came from Jaycar
                    Catalogue No. ZD-1952.
                    Just found its data sheet but no capacitor details.
                    • CapLeaker
                      Leaking Member
                      • 8344
                      Re: Capacitor ID
                      If you want, change it over to electrolytic. Capacitance is not that critical there, but is surely would something back in. The only problem is to obey the polarity when you do change it over to electrolytic anything between 0.33 and 1uF should do the trick.
                        • 31265
                        Re: Capacitor ID
                        if you change the sensor, dont mix up 5v ones with 3v ones.
                        • humble
                          Tinker
                          • Aug 2014
                          • 12
                          Re: Capacitor ID
                          Thnx stj.
                          I managed to buy smd caps but they made no difference.
                          With the IR board back in the tv the IR board frequency outputs from pressing the various remote buttons match those on another (good) Toshiba; e.g. with the Fluke set to DC volts & frequency, "power on" remote button =18.42Hz, "menu" =18.27Hz, "5"=18.35Hz etc.
                          I assume this is how the buttons are differentiated.
                          Next step seems to be to follow the signal to the main board.
                          Lacking a specific wiring diagram I expect it to lead me to a 48 leg IC & no idea of which output leg I need to test.
                          As Australian bush ranger Ned Kelly said before he was hung, "Such is life", but as the copper that wounded him may have said "The thrill is in the chase"
                            • 31265
                            Re: Capacitor ID
                            maybe it's just the cable!
                            • humble
                              Tinker
                              • Aug 2014
                              • 12
                              Re: Capacitor ID
                              Fixed.
                              With the new IR input sensor & 0.33uF input cap but no output cap (there never was one) everything works OK.
                              Perhaps the new IR sensor was unnecessary but it was a cheap first step.
                              Many thanks.
                              • CapLeaker
                                Leaking Member
                                • 8344
                                Re: Capacitor ID
                                great to hear!
                                • MORETTIGIAN
                                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                  by MORETTIGIAN
                                  Title:
                                  Description:
                                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                                  Procedure performed:
                                  - Removed backplate
                                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                  - Reapplied thermal compound
                                  - Reassembled card
                                  Observed behavior after reassembly:
                                  - GPU powers on and operates normally under...
                                  09-18-2025, 12:14 PM
                                • CapLeaker
                                  AcuRite 5 in 1 temperature sensor replacement repair
                                  by CapLeaker
                                  Got a new victim:
                                  AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                  A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                  B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                  Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                  04-15-2025, 01:32 PM
                                • Prolog
                                  RTX 3080 FE Identifying capacitor
                                  by Prolog
                                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                  I hope these photos make it clear which component I am referring to:
                                  (yes, the soldering is a bit botched from removing the blown one, I know)
                                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                  12-01-2024, 08:27 PM
                                • Agent24
                                  Dick Smith Q-1760 linear power supply filter capacitor question
                                  by Agent24
                                  I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                  It has at least one problem.
                                  The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                  I have already ordered a replacement potentiometer, so that's not an issue.
                                  Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                  All are CapXon...
                                  10-21-2025, 05:39 PM
                                • chth96
                                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                  by chth96
                                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                  I know that these capacitor will not last as long as nichicon capacitor...
                                  12-22-2023, 04:34 AM
