LG Backlight out, Please Help
  • bjlasota
    • Aug 2015
    • 17
    Good morning,
    I have an LG 32LE5300-UC that recently stopped working. When I plug the tv in and turn it on, the LG symbol comes up, then the static, then after about 10-15 seconds, the backlights go out. This is an LED TV. I can see and mess around in the menus when I shine a bright flashlight on the screen.
    I have replaced the Power board which also came with a new LED drive since it's part of that board and it still has the same issue. As far as I know, there's only 3 things that can go wrong with an LED. The power board(changed), the Tcon board(but I shouldn't see a picture even if with a flashlight right?), or the control board(which wouldn't be bad if I can play with the menus?).
    Can anyone help me out in figuring out what the issue might be? What tests can I do to maybe pinpoint the issue?
  • Terryfictv
    • Mar 2011
    • 124
    Re: LG Backlight out, Please Help
    Bad LED / LED strip inside panel.
    • bjlasota
      • Aug 2015
      • 17
      Would a defective LED bulb temporarily light though? When I turn the tv on, there are LED's all over the whole tv. I can see the picture perfectly from the front, and with the back off, I can see a ton of LED bulbs lit up. They all go out at once. And it's repeatable. Turn tv off-turn back on, all lights back on, then go out again and stay out. If this still points to a bad bulb, what kinda work am I looking at to replace a defective bulb? And how would I determine which bulb is bad if they all come on and all go off at the same time?
      • jts1957
        • Dec 2008
        • 38
        YES!
        You've received the SAME answer on (at least) three forums.
        Disassembly of panel until you can see ALL LEDs at once, or remove from panel and hook them back up.
        http://www.ebay.com/itm/LG-LC320EUH-...-/180571777615
        • bjlasota
          • Aug 2015
          • 17
          So after tearing everything down, I found 1 bad led on the lower right board. I've googled the cap out of part numbers and have come up empty handed. I see the eBay part your posted, but I think that a new led board should exist somewhere. Is there an online store where I can get a replacement or can I maybe buy a cheaper led strip that will fit, put. New connector on the wires and go that route?
          • jts1957
            • Dec 2008
            • 38
            Unfortunately ALL manufacturers make their money by selling TVs, NOT parts.
            They may have a very limited supply of Panels, LED strips, or possibly the individual LED bulbs, but whatever they have would be furnished for warranty purposes.
            Of course, you can try to find a replacement LED with similar characteristics, possibly Digikey, Mouser or even one from a similar strip.
            I seem to recall reading, i believe it was here, that dead LED could be bypassed with a regular diode.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              If its just one (1) LED that is bad you could simply bypass that LED with a 1N4001 diode and the set will work or just use a wire bridge.
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • repair-it
                TOSHIBA DLP 52HM95 How to reset timer module on bulb
                by repair-it
                I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                10-11-2023, 07:18 PM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • cheebster
                iPad Pro 12.9 5th Gen Backlight Issue
                by cheebster
                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                Anyone...
                05-20-2025, 09:17 AM
              • ezenia
                LUMIMAN Smart Bulb IC ID?
                by ezenia
                I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                04-28-2025, 05:56 PM
