Insignia (Samsung) NS-P502Q-10A Plasma single vertical sparkling line issue
  • slowcorrado
    • Jul 2011
    • 3
    I recently picked up a used Insignia NS-P502Q-10A 50" plasma TV that would not power on from a friend. "Please see if you can fix it for cheap" (We've all heard that)
    It had a badly arcing y-sus board (would crack and spark like a stun gun!) so I threw in a replacement, checked all connections and grounds and it fired right up. The picture is excellent and all functions work, except for one thing! There's a single line of sparkling pixels on the left edge of the screen. (See pic for an example it looks like more, but it is only one line) In the bad old days I would have thought it was some type of overscan adjustment on a tube-type tv. But I just don't have enough experience to know where to start here. I didn't do any adjustments on the YRR or VSCAN pots on the replacement board, but my limited knowledge didn't lead me to believe this would make a difference as the black levels are good. For reference, the board I replaced was a Samsung LJ41-06153A.
    Any help would be appreciated! Thanks.
  • mmartell
    • Oct 2013
    • 3189
    Re: Insignia (Samsung) NS-P502Q-10A Plasma single vertical sparkling line issue
    Usually indicates a bad panel. Check connections to the lower address buffer board in that area with the power OFF.
    • sputnikoff
      samsung un58tu7050 single vertical line.
      by sputnikoff
      Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
      02-25-2023, 09:42 AM
    • cubytus
      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
      by cubytus
      Hi to all,
      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
      01-10-2024, 01:26 AM
    • otaku_nut
      Vizio E701i-A3 fixed but now has red vertical line
      by otaku_nut
      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
      08-19-2025, 06:11 PM
    • TrueSword88
      Kogan - KALED65XU9220STB - Blue Vertical Line
      by TrueSword88
      Hi all.
      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
      The line just happens to coincide with the end of COF and start of the next COF (attached).
      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
      Hoping to fix...
      05-05-2023, 04:28 PM
    • FALKLAN
      Running Line Voltage and Integrating LED Pods - Automotive
      by FALKLAN
      Howdy everyone! I hope all is well where ever you are!
      I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
      I am uncertain how to convert this line into a switched 12v output line for the LED pods....
      02-05-2025, 12:30 AM
