samsung un58tu7050 single vertical line.
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
    • 12328
    • U.S.
    Re: samsung un58tu7050 single vertical line.
    clean and reseat the cable/s to tcon and or panel driver boards, can use ipa alcohol, some use a pencil eraser, not to vigorously they can be fragile.
    • sputnikoff
      • Feb 2016
      • 203
      • canada
      perfect sir... i will give it a try.
      • sputnikoff
        • Feb 2016
        • 203
        • canada
        Pics
        • lotas
          • Jan 2016
          • 4840
          • Russia
          Originally posted by sputnikoff
          Pics
          It can't be fixed anymore.
          • sputnikoff
            • Feb 2016
            • 203
            • canada
            Hey lotas have u had this issue before without any fix?
            • lotas
              • Jan 2016
              • 4840
              • Russia
              You can see everything in the photo.
              Poor contact of the cable with the matrix (with glass), a problem with the column decoder, or a defect in the matrix itself.
              • sputnikoff
                • Feb 2016
                • 203
                • canada
                Thanks lotas haven’t had lot of these particular issues.unit initially had no screen I assume it was shorted but I cleaned up connection so picture came back but with this problem.
                  09-07-2024, 05:50 AM
                • mrsith
                  Samsung UE58TU7100K - no picture, vertical line
                  by mrsith
                  Hi.
                  Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                  This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                  Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                  02-07-2023, 11:18 AM
                • kotel studios
                  Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                  by kotel studios
                  Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                  In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                  08-06-2025, 02:07 AM
                • otaku_nut
                  Vizio E701i-A3 fixed but now has red vertical line
                  by otaku_nut
                  Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                  08-19-2025, 06:11 PM
                • madyoyo
                  Samsung eu58tu6928k - Short on CK3 line -
                  by madyoyo
                  Hello.
                  I have a Samsung eu58tu6928k with the dreaded bootloop fault.
                  No external tcon, one 96 pins ribbon between mainboard and the left side of the panel, and a ribbon to the right side.
                  I narrowed the problem down to the CK03 line. When i isolate only this line on the ribbon joining the 2 halves of the panel, the tv boots, but the picture is quite bad. I also tested all MLCC caps on the panel, no short so far. Is there anything i can try before ruling the panel, and the whole tv as scrap?...
                  11-05-2025, 04:55 AM
