Panasonic Plasma TC-P50S2 Lightning Dead
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TC-P50S2 Lightning Dead
    Originally posted by hrpuffnstuff
    love the conversation and advice!!! i'm looking for the link right now for the $150 board...by the way that first moduslinkspts link that you cited takes me to a sufix AC board...mine is a sufix AB board...my guess is that it makes a difference
    can we get a picture of the A board. owned this from new? AB revision is looking like a 46" board. this is a 50S2, yes?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Thanks, Man. I guess your username caught me. Brought back some fond memories. Let us know how it turns out. Good Luck....
      • hrpuffnstuff
        • Aug 2015
        • 14
        Thanks again...yes, I have owned since new and never had a problem...the pics should show the pertinent info...night time here so I apologize that I had to use flash instead of natural lighting
        • tw2005
          • Oct 2011
          • 6458
          yes it does show pertinent info. rev of your board is AC
          • hrpuffnstuff
            • Aug 2015
            • 14
            yep...i just watched the shop jimmy video of how to find suffix revisions...i assumed the "AB" located near the "SUFFIX" letters meant it was an "AB" version...but it looks like the jumber locations under the suffix letters determine the version...seems to me this is great news! thanks again TW
            • tw2005
              • Oct 2011
              • 6458
              i guess it is because modus charge $180 for rev AB. Also means you won't pay $150 for the incorrect board
              • hrpuffnstuff
                • Aug 2015
                • 14
                absolutely...thanks for all your help!
                • nicktorna
                  • Aug 2015
                  • usa
                  #28
                  I too had a power surge jack my tv up.
                  I replaced the power board and media board (had no power) and now have a crappy picture. I then replaced the sustain and buffer boards but now have no picture (may need to return the sustain and buffer boards).
                  Should I try replacing thr sustain and buffer boards again or is my tv toast?
                  • bwilliams60
                    • Aug 2014
                    • 109
                    It would be in good taste to start your own thread instead of hijacking one. It leads to too much confusion for those trying to help the OP.
                    When you start the thread, include make, model, problem and any pertinent information as to how and when it died, and pictures of the back of the set with cover off and any boards you can show us. Then, the forum can help you out. Hope this helps and you find success in all your repairs.
                    • hrpuffnstuff
                      • Aug 2015
                      • 14
                      I just wanted to close the circle on my thread and provide an update. I sent my A-board to Moduslink PTS last week. They repaired the board, and it was delivered to my house today. I just finished installing and everything works with the same beautiful picture! Is a slight hum coming from the P board and SC board normal when viewing a bright picture? I have never had the tv apart before, so I never was close enough to notice this slight hum and wouldn't know if it were normal before the lightning strike. Also, part of the troubleshooting process involved a standby light. I learned today after putting everything back together and turning the tv on and then off that there is no standby light. What I thought was the standby light looks to be the remote control receiver window next to the power light. So again, thanks to all who helped!
                      • tw2005
                        • Oct 2011
                        • 6458
                        yes, normal. faint buzz on a SC at high brightness and would expect some hum from the P.
                        It's funny when you get up close and work on these once they've failed how paranoid you can get with buzzes. like you say , you just watch the damn thing, who gets up close and listens to the boards.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          #32
                          Very good, my Friend!!! Thanks for the feedback...
                          • badcappo
                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                            by badcappo
                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                            Diode type G972s6 - D101 with a short
                            Mosfet 06N90E - Q301 shorted
                            Fuse T5AH 250V - F103 blown
                            Diode D301 shorted
                            Relay DG1U-17VDC II - RL001 blown
                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                            11-24-2024, 11:27 AM
                          • jm1234
                            Panasonic plasma TX-P42ST50 - 6 blinks
                            by jm1234
                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                            I checked that board for any obvious faults...
                            05-22-2024, 06:59 AM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • cloo
                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                            by cloo
                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                            After doing a factory reset this problem was gone and the picture was back to...
                            01-06-2025, 06:02 AM
                          • Eaglecrest
                            Panasonic plasma color stripe
                            by Eaglecrest
                            I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
                            11-05-2025, 06:16 PM
