LF501EM5F No Power, Chirping/Beeping Transformer
  • shadetreetrader11
    • Oct 2015
    • 230
    Re: LF501EM5F No Power, Chirping/Beeping Transformer
    Is it possible that IC601 is just bad? Can I lift just the one leg of the IC601 and see if 20volts is being produced or is that not smart?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8220
      Not smart. You don't lift a pin on an IC. Either you take it off or leave it on. VCC isn't produced there. That is the input voltage required for the IC to work properly. So we got to follow the line back. VCC has to have at least 14V in order for the IC to turn on.
      • SLK001
        • May 2014
        • 264
        Originally posted by shadetreetrader11
        c611 is measuring 17 ohms with esr meter. Seems high but I'm not at all familiar with ceramic caps.
        WAAAY too high. ESR of a ceramic should be less than 0.1 ohms.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8220
          That is a ceramic cap, not a electrolytic. ESR depends also with what frequency you test. You don't test ESR on a ceramic cap.
          • SLK001
            • May 2014
            • 264
            Sure you do. ESR is just as important for a ceramic cap as it is for an electrolytic cap. However, the ESR of a ceramic cap is usually <<0.1 ohms.
            Measuring 17 ohms on any cap, especially a ceramic, indicates either 1) serious problems, or 2) measurement error.
            • shadetreetrader11
              • Oct 2015
              • 230
              I did change the capacitor out but it didn't help the situation
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8220
                I figured so... go measure a ceramic cap with a ESR meter at different frequencies and see what you get. There is no point of measuring ESR on a ceramic cap on this power supply.
                  Right now the circuit is working otherwise you will not have any of the outputs Voltages at all, it is just not putting out the correct Voltages, and we are not going to have any boosted Voltage because it is getting the VCC to run the PFC IC from the AUX winding of the main transformer which I am pretty sure that it is also low, it also need the PS-ON for the PFC to come on line.
                  What resistance do you have between GND and the ALL+3.3V line?
                  • shadetreetrader11
                    • Oct 2015
                    • 230
                    All+3.3 to ground is 56.3k
                    All+3.3 to ground with the 470 ohm resister to p on is 3.4k
                    • shadetreetrader11
                      • Oct 2015
                      • 230
                      I just thought of something. Should I take the transistors or mosfets or what ever they are out of circut to check them? Q17014 Q1601 Q1602 Q601 They are attached to the alum. heat sinks I know for a fact none of them are shorted. But as far as working properly I can't really say
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8220
                        no. If there would be something wrong with those, you would know it. For some reason the circuit does not start. We proved that already by not having enough voltage on the IC. Let it be a starting cap, a starter resistor etc. Did you check those capacitors in post 58?
                        • shadetreetrader11
                          • Oct 2015
                          • 230
                          I'll spend some time just poking around with the ohm meter maybe I'll get lucky ha ha
                            Spec sheet of the FA5640:
                            Page 12:
                            Start up minimum Voltage is 12.5V, 14V Typ.
                            Under Voltage shutdown can be as low as 7V, 8V typ,
                            Right now you are getting Voltages at outputs (AMP13V and P-ON 21V) side so the IC is running otherwise you will have 0V at the output side of the transformer rectifier circuits.
                            You can verify that the IC does start up and run or not by lifting one of the 3 resistors R610, R611, or R614 which feed pin 8 (VH) for the internal charge pump circuit and see if you will have any DCV at the output side of the transformer at all.
                            After looking and studying how the circuit function, I suspect the problem is at IC651 (1117 series 3.3V fixed LDO regulator) or open circuit or high resistance at the input pin due to bad resistors connected to the input pin, it should have about 8VDC feeding the input pin right now (that is what you reported for the AMP13V), that is more than enough to get the IC651 to put out 3.3VDC at low current to run the main board in standby mode.
                            Once the PS-ON is present then Q653 is turn on so the feedback resistor R667 is grounded out so the output Voltages will go higher to maintain the higher output Voltages and keep the sensing pin of D650 (431 shunt regulator Diode) at 2.4V) which causes the rest of the Voltages to go up to the proper level. They had to keep the out put Voltages at low level in standby mode so the power consumption will be low, that is why the 13V and the 21V are low right now since it is not required full Voltage in standby mode, it will kick up to proper Voltage and then the 3.3V will be handle by Q657 which can handle more current than the 1117can supply when TV is in full on mode and requires more current from the 3.3V power supply, at the same time the PFC Voltage booster will be running also.
                            So the bottom line, in standby mode:
                            The AMP+13V will be around 8V. This 8v is high enough to feed the 1117 3.3V LDO regulator IC to provide 3.3V at low current to run the main board in standby mode.
                            The P-ON-+21V will be around 13V
                            You can also see that the 13V and the 21V is putting out at 60% of the normal Voltage and being maintained at that level in standby mode.
                            The ALL+3.3V SHOULD BE AT 3.3V!
                            So you need to check the Voltage at IC651 1117 3.3V
                            • shadetreetrader11
                              • Oct 2015
                              • 230
                              My board didn't come from the factory with IC651. The Board I have is ba3au0f0102 3. Now having said that I down loaded a print off the Internet and It also has IC651 in it.
                              • shadetreetrader11
                                • Oct 2015
                                • 230
                                  Schematic on my post #45 is the one I use.
                                  So now we have to trace out the connection from the 3.3V pin to see where it goes to, this is not going to be easy.
                                    OK the diagram does not match the board BA3AU0F0102 3.
                                    Emerson A3AUNMPW-001 Power Supply Board.
                                    http://www.shopjimmy.com/emerson-a3a...upply-unit.htm
                                    • shadetreetrader11
                                      • Oct 2015
                                      • 230
                                      • shadetreetrader11
                                        • Oct 2015
                                        • 230
                                        Should we chalk this one up as a loss and I order one? It's up to you I'm game. But for now I'm going to bed. Have to be up at 6.30
                                          No, not yet!
                                          Is this your main board?
                                          It looks like the ALL+3.3V is generated on the main board!
                                          http://www.shopjimmy.com/emerson-a3a...ain-board.htm#
                                          If it is, look at the P/N of IC3602.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
