Vizio xvt553sv reporting m470nv main board
  • chandan7
    • Dec 2014
    • 11
    • India
    My Vizio xvt553sv recently stopped working after a power surge. After asking for help in this forum, I found that the mainboard needs replacement. I bought a mainboard with the exact matching number 3655-0122-0150 which the seller specified is for Vizio XVT553SV.
    However, after plugging in the mainboard the TV I am noticing several issues.
    1. It does not boot up in one go. First it boots up for a long time then turns itself off and turns back on. And after the second boot up the TV stays on. The whole cycle takes a long time and happens everytime I turn on the TV.
    2. The TV is unable to detect my bluetooth remote. I tried pressing the record button + green button, but it could not discover the remote. I also tried the "hold down the Q, P, and Spacebar" thing, still nothing.
    3. The wifi does not scan anything.
    4. While the board has 4 hdmi and 1 side hdmi ports, the OSD when pressing "input" only shows 3 hdmi and 1 side hdmi
    5. When I check the system info in help, I noticed something strange. The model on the mainboard reports itself as m470nv.
    How is that possible? The mainboard does have 5 hdmis and the number is correct on the mainboard for what it should be for xvt553sv. Did the ebay seller somehow flash the wrong firmware on the board or change some chip?
    Please help!
    Re: Vizio xvt553sv reporting m470nv main board
    May be he sold you bad board.
    • chandan7
      • Dec 2014
      • 11
      • India
      Thank you for the prompt reply @budm. So there is nothing that I can do? Flash a new firmware or something?
      • ecking767
        • Oct 2009
        • 492
        sound like a factory programming error, you can confirm this by removing the metal shield on the main board to look to the flash memory chip. Vizio mark these flash memory chip with a color marker like white, blue or red.
        in your case just return the board back to the seller.
        and check this
        http://www.ernestos-electronics.com/...re-update-fix/
        • maricm
          Vizio P65 with P55 mainboard
          by maricm
          IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
          Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
          And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
          04-23-2024, 08:25 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • Devonavar
          Vizio M43-C1 - How closely do I need to match the mainboard number?
          by Devonavar
          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
          So, I've ruled out the PSU for now.
          The reboot loop...
          08-14-2022, 08:46 PM
