Sony 46X3000 errors
  • OracsRevenge
    • Feb 2015
    • 13
    • United Kingdom
    Sony 46X3000 errors
    Hi folks,
    I have a Sony 46x3000 that came to me with the led flashing 8 times, couldn't find anything obvious with the audio system so swapped the AE aboard.
    The 8 flashes have now gone, the green led comes on and the Sony logo lights up on the frame, but no backlight.
    Then after 30 seconds or so it switches back to flashing the led 5 times. I believe this indicates a TCON error according to the service manual.
    Checked connectors and TCON fuses, all seem to be ok.
    Any advice on where I should go next. I am tempted to now order a TCON, but a little worried that with two different errors on the TV I may be looking at a power board voltage issue, or maybe a voltage spike went through the set.
    Any advice greatly appreciated.
    Pete
    Re: Sony 46X3000 errors
    "Checked connectors and TCON fuses, all seem to be ok." So do you get VCC at fuses?
    • OracsRevenge
      • Feb 2015
      • 13
      • United Kingdom
      Good point.
      I checked the voltage at the main T-con fuse and it is going from 12v down to zero once every 2 seconds.
      Traced this back to the Panel 12V on the UB1 board which is switched through by the Panel_on signal coming from the Main board micro-controller which is showing the same pattern. (voltages from the PSU are steady 12V)
      I am not sure if this is telling me much, could just be that the micro turns on the T-con and if it doesn't get a correct response, it turns it off and tries again a second later. Altough this seems like a pretty drastic way of doing it.
      Oddly, it seems in this service manual that the T-con isn't listed as it's deemed to be part of the panel and there is a UB1 Motion compensation board in-between the T-con and the main board.
      There is no attempt at a back-light which may also be significant.
      Pete
      • OracsRevenge
        • Feb 2015
        • 13
        • United Kingdom
        Uploading the Service Manual timed out on the board so I saved it to my server.
          The main board is the one that sends out the PANEL_ON command.
          How about other Voltages on the connectors? only the PANEL-ON command is fluctuating?
          What is the flashing code now at this point?
            Sch. i had to split them into smaller parts.
            • OracsRevenge
              • Feb 2015
              • 13
              • United Kingdom
              Just checked every voltage test point I could find and all seems as it should be.
              The TV power light turns green for about 30 seconds then back to red and flashes 5 times indicating a T-con issue.
              No backlight comes on during this time.
              I put the old AE board back in and it went back to 8 flashes (audio error).
              I did find another similar fluctuating signal on the PSU connectors on pins labelled DIMMER. Seems these are originally fed from the same Microcontroller on the main board.
              Pete
                "The TV power light turns green for about 30 seconds then back to red and flashes 5 times indicating a T-con issue" So what DCV do you get at the T-CON board still fluctuating same for the Control signal for the T-CON panel-power?
                We still need good pictures of the whole backside of the TV so we can see all the boards.
                "Just checked every voltage test point I could find and all seems as it should be." At which connectors and at which boards? And how about the signal pins what DCV do you get when TV is OFF and when TV power switch is activated and then after it goes into shutdown mode?
                3-8-5.
                When the TV Set has a T-Con error please check the following:-1.Check the BE micro pin 128 on the FB2 board.2.Replace the panel module.
                The schematic is not easy to read due to pages are spitted into many pages.
                The diagram is really confusing, the T-CON 12V is connected UNREG 7V?
                • OracsRevenge
                  • Feb 2015
                  • 13
                  • United Kingdom
                  The DCV at the T-con board is fluctuating with the Power on Signal
                  The connectors I checked were mostly on the PSU board as I it's screen printed with the voltages. so below is when the TV is powered up.
                  All 12V lines are 12.28 and remain that way on standby
                  All 6V lines are 6.13V and remain that way on standby
                  Audio_Vcc is 13.77
                  DIMMER changes from 3.2v to 0.02v every 2 seconds
                  Balancer_err = 0v
                  Inverter_err = 0v
                  Back_light = 0v
                  AC_rly = 4.83v
                  PFC_DET = 2.94V
                  PS_Err = 0v
                  Stby5v = 4.86v (same when on standby)
                  There are brown and white wires that head to the inverters that are at 594VAC
                  As I was testing these voltages (probably around the inverter power area, a curious tings happened. My daughter said the TV started glowing. Sure enough, the backlight was on, which it had never been before. Maybe I disturbed a cable or connector somewhere.
                  When the TV is powered on now, after 3 seconds the backlight comes on. I used the remote to ramp up the volume and I could hear static from the speakers. I then connected a HDMI source to the TV and once I figured out how to change the source blindly, I managed to get audio output from the speakers.
                  However, still no picture or OSD on the screen.
                  It did revert to the 5 flashes once again after that, but cleared again after a power reset.
                  I think at this point I need to try to figure out which board to replace next as they are not that expensive on Ebay.
                  I am leaning towards the FB2 or UB1 boards at the moment. If the TCON needs replacing then that will be a challenge as it seems to be part of the panel on this model. (plus no mention of it in the Service Manual, only to replace the panel module for a TCON error)
                  Flow chart in the manual says "Check
                  LVDS harness
                  (FB2/UB1 and Panel)
                  FB2 / UB1 board
                  Panel Module"
                  Is there an easy way to tell if the FB2 (main board) is outputting a signal to the UB1 motion compensation board? or the UB1 board to the TCON? I have a DVM, but my haven't turned on my oscilloscope for a few years and seems to be a bit temperamental.
                  Moving the LVDS cable around doesn't seem to change anything.
                  Photo attached.
                  Pete
                    The T-CON board is under that metal shield, the connector on the bottom of the board is connected to the FRC (Frame Rate Conversion) board, then the connector of the bottom of the FRC board is connected to the main board.
                    So you you remove that shield to get to the T-CON board fuse? T-CON bd is replaceable.
                    https://flattvparts.co.uk/lcd-tv-par...ny/kdl-46x3000
                    I still do not understand why the Power on command is fluctuating but the 12v, 6v, pfc det are steady.
                    • OracsRevenge
                      • Feb 2015
                      • 13
                      • United Kingdom
                      Yes, I had a go at removing the Tcon board a few days ago but it's pinned in by the metal bracket that seems to be supporting the panel, will have to take a lot off to get to it. Luckily the TCON power fuse was on the lower edge of the board that is accessible.
                      The linked diagram shows how the panel_on signal switches through the main 12v through to the Panel 12v which is the power for the T-con board. This is why the fluctuating signal is turning the Tcon on and off.
                      I left the TV off for a while, came back in and it's back to 5 flashes
                      http://www.ukrobotgroup.com/Downloads/tconpower.jpg
                      (attachment uploader not working for me tonight)
                      • Daren87
                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                        by Daren87
                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                        08-13-2023, 03:25 PM
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
                      • iglitare
                        by iglitare
                        09-04-2025, 07:13 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • rimwall
                        Sony KD-65x7500D - double image - Tcon or Panel?
                        by rimwall
                        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                        11-18-2025, 02:09 AM
