how to determine if its a bad main or tcon?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I am working on a few sets that the backlight lights up but no picture how can I determine if its a bad main or tcon?
  • lookimback
    • Aug 2013
    • 1489
    Re: how to determine if its a bad main or tcon?
    Add panel to that too. No picture can also be caused by a bad panel. I usually begin by disconnecting the ribbon cables which connect the Tcon to the panel address boards. Do one at a time and cycle power. If you get a picture on one side, your main board is good and the problem is likely the panel.
    ------------signature starts here------------
    • CapLeaker
      Leaking Member
      • 8325
      take a 100Mhz oscilloscope and look at the LVDS signal that goes from the main board to the tcon. Flick the menu button on and off and you should see the signal changing in the oscilloscope.
      Sometimes disconnecting one cable at a time from the tcon to the panel wont work. At least it didn't on the last 60" Samsung that I fixed.
      Do some research of your TV model number at SJ for instance.
      Also check the fuses on the tcon!
      • mattstolte
        • Dec 2013
        • 612
        • usa
        i dont have a scope. and what about sets that just have 1 ribbon to panel and screen lights up but no picture how can you determine then if its tcon or main?
          You can start by at least checking the DCV feeding the T-CON, then there are 2~3 switching power supplies on the T-CON and regulator ICs which you need to test the Voltages. If some of the Voltages are not present, then disconnect the ribbon cable/s between the T-CON and the panel to see if the Voltages come back. Most of the T-CON boards have test points for testing the Voltages.
          https://www.badcaps.net/forum/showpo...&postcount=202
            If all the voltages are good and there is nothing else obviously wrong the only way I know of is to use a scope to check the LVDS signals like CapLeaker says
            • iglitare
              by iglitare
              09-04-2025, 07:13 AM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • Awsmessymail
              Vizio E701i-A3 backlight only and now no backlight
              by Awsmessymail
              Hello all,
              I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
              I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
              As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
              02-13-2024, 11:04 PM
            • maxim2511
              LG 55EC930V OLED - swich on swich of no screen
              by maxim2511
              My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
              Then I get an idea to take it apart and clean boards from dust.
              In side of Tv was not so bad, I take compressed air in can, and gently blow up.
              Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
              05-14-2021, 02:21 AM
