JVC VM-42V31 plasma goes to standby flashing Red LED
  • LesWoollam
    • Nov 2012
    • 69
    • United Kingdom
    My JVC VM-42V31 plasma has suddenly developed the following fault:
    Switch-on - steady green front panel LED comes-on. All 3 x power board LEDS come-on
    After about 10 seconds the power board relay trips, LED8001 and LED 8002 on the power board extinguish and the front panel LED changes to a flashing red LED (flash rate - aprrox. 1 per second).
    I've unplugged both the Y-Sus and X-Sus boards but the fault remains the same.
    Any suggestions would be very gratefully received.
    Many thanks.
  • LesWoollam
    • Nov 2012
    • 69
    • United Kingdom
    Re: JVC VM-42V31 plasma goes to standby flashing Red LED
    Still no joy with fixing this
    Does anyone know what the LEDs on the power board indicate? That might at least help isolate the fault.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Send pics of the backside of the TV and close up shots of the PWR Bd. Close up shot of the PWR Bd jack that goes to the Main Bd. I may be able to give you a procedure to test the PWR Bd.
      • LesWoollam
        • Nov 2012
        • 69
        • United Kingdom
        More to follow. . .
        • LesWoollam
          • Nov 2012
          • 69
          • United Kingdom
          Hope these help.
          Many thanks!
          • 7ony
            Samsung plasma - flashing standby light
            by 7ony
            The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
            Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
            Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
            No visible...
            08-31-2020, 05:18 PM
          • check12
            Samsung Plasma PS43F4500AW Won't Start (flashing standby)
            by check12
            Hi ... Samsung Plasma PS43F4500AW ... when powered with 240V mains standby flashes, pressing PWR button causes standby LED to go out but nothing further happens.
            I have already removed and benched the SMPS, jumpered PS_ON to GND, VS_ON to 5.3v and have VS & VA voltages and all other voltages available at CN4007.
            VS=213v
            VA=58v
            SVT_VS=213v
            This suggests to me that the SMPS is probably ok but I have no experience of TV repair so could do with some help.
            I have removed the XY-Drive board and checked all the ribbon cable...
            11-21-2021, 07:46 AM
          • XCon
            LG 60PN6500 Plasma with standby, but won't power up.
            by XCon
            Symptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
            So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
            The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector...
            06-27-2025, 05:30 PM
          • Willem01
            TV not powering on - with standby red –led flashing
            by Willem01
            Error – TV not powering on - with standby red –led flashing
            Model- LEDTV – 39T3500
            Power boarD - shg3206a-101h
            I have read through the Basic LCD TV and Monitor troubleshooting guides.
            https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
            In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
            Unplugged the power connector on the board, I plugged the power cable in waited...
            02-27-2021, 08:23 AM
          • STKR123
            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
            by STKR123
            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
            I wonder if re-flashing the BIOS might be of any use here.
            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
            11-03-2024, 06:58 AM
