Lg50pg6010 line
  • adamp91gvm
    • Jan 2014
    • 706
    • uk
    Lg50pg6010 line
    Hi all got this lg with a few swollen caps repaired them and there was a faint line down th screen and i left it onnto see if it would come back to life and there was a click then the line gree 2 inchs any ideas
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg50pg6010 line
    Bad panel by the look of it.
    You could try reseating the ribbon cable in conjunction where the line is.
    • adamp91gvm
      • Jan 2014
      • 706
      • uk
      Re: Lg50pg6010 line
      Tried putting it in and out but nothing
      • otaku_nut
        Vizio E701i-A3 fixed but now has red vertical line
        by otaku_nut
        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
        08-19-2025, 06:11 PM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
      • FALKLAN
        Running Line Voltage and Integrating LED Pods - Automotive
        by FALKLAN
        Howdy everyone! I hope all is well where ever you are!
        I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
        I am uncertain how to convert this line into a switched 12v output line for the LED pods....
        02-05-2025, 12:30 AM
      • mindoverflow
        ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
        by mindoverflow
        hello,
        there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
        I changed pads and thermal paste.
        I run mats test but it is reporting 0 errors.
        I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
        After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
        02-09-2022, 03:22 PM
      • madyoyo
        Samsung eu58tu6928k - Short on CK3 line -
        by madyoyo
        Hello.
        I have a Samsung eu58tu6928k with the dreaded bootloop fault.
        No external tcon, one 96 pins ribbon between mainboard and the left side of the panel, and a ribbon to the right side.
        I narrowed the problem down to the CK03 line. When i isolate only this line on the ribbon joining the 2 halves of the panel, the tv boots, but the picture is quite bad. I also tested all MLCC caps on the panel, no short so far. Is there anything i can try before ruling the panel, and the whole tv as scrap?...
        11-05-2025, 04:55 AM
