sony bravia kdl26ml130 no IR remote signal at MB connector
  • manstoblame
    • Jan 2011
    • 85
    Hey y'all got a problem with a kdl26ml130 Sony bravia. At first I thought the IR sensor was bad on it bought a replacement still same problem. Began testing ir board for voltages every resistor and capacitor tested in the 3.3v range, a couple half that. What I did notice was a few chips on the mother board (main/digital) by the connector that were reading ol but have no clue what they're rated. When the schems say its a short chip, does'nt that mean it's just a jumper wire basically? The chip has a O on it, also when my meter probe touches it and the one below it the channel on the set changes. Just curious as to whether I am in the right area here is an image of the pin connections from the manual key and the IR board to the MB chip 3267 I believe is the culprit and as I said when touch probe between the two the set switches channels. Also component 3264 only measures 0.82v schematics parts list it as a 0 uh(micro Hertz) ferrite should it also measure the 3.3v standby. That's right ain't it? Any helps needed and appreciated. Can't load from tablet will load from laptop when editing, in a few moments...
    Re: sony bravia kdl26ml130 no IR remote signal at MB connector
    "0 uh(micro Hertz) ferrite should it also measure the 3.3v standby"
    Zero micro Henry not HERTZ? Where did you get the 0uH from? Ferrite bead resistance between the two terminals of the ferrite will be very low, usually <1 Ohms or so.
    How about up load some good clear pictures of what you are probing and the diagram you are using?
    "The chip has a O on it, also when my meter probe touches it and the one below it" What is the 'one below it' ? It? I have no idea what you are trying to say.
    • manstoblame
      • Jan 2011
      • 85
      trying to post pics now but if what you are saying about an ohm or greater is 0.87 an ohm?
      • manstoblame
        • Jan 2011
        • 85
        sorry budm can't load attachments right now bro have to try later but will do for sure because you have helped me in the past. apologies for the crappy post trying again later to post schematic images Oh just doing a dc voltage check grounded to set probing. the 0 Uh came from parts list in service manual but hey I will get back to you when I have all things in order
          "0.87 an ohm" so it does not have open circuit so the part is OK, 0.87 is probably your test lead resistance..
          < is the less than symbol not greater than.
          > = greater than.'
          • manstoblame
            • Jan 2011
            • 85
            for some reason I cant attach try links: https://drive.google.com/file/d/0B_E...ew?usp=sharing
            I know its been a long time since I have been back to this post.
            Anyone willing to help will have to spend a little time looking so much trouble trying to get something up to show what I am talking about that I did not have a chance to point out things with arrows sorry. Links are google drive hope you all can view. CN**** is where the manual controls and the remote IR also connects buttons work remote wont.
            • JUCaESAl
              Sony bravia KD-65AF9
              by JUCaESAl
              Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
              Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
              10-20-2025, 04:03 AM
            • PopsCaps
              Sony Bravia KDL-40V2500 that will not power on
              by PopsCaps
              I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
              I do not hear any sound and I cannot see any backlight.
              I have tried disconnecting every cable on each board one at a time to see if anything changes.
              The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
              My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
              03-25-2025, 11:23 AM
            • alegatorul
              sony bravia kdl-43w756c, no power, no sound
              by alegatorul
              the charger brick has 19,2-19,3 vcc
              changed the inverter board same result.
              where should i start?
              cheers
              11-15-2025, 10:00 AM
            • Tomylee
              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
              by Tomylee
              Sorry for the person who’s going to read all this !
              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
              07-11-2025, 11:52 AM
            • justin35
              Sony bravia kdl-43w755c - boot loop
              by justin35
              i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
              from what i read online it looks to be an emmc issue…
              i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
              i took out the board and say an samsung 16gb emmc
              i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
              i could try to put one instead of the 16gb one, but will it work?
              where do i get the software from?
              any help will be much appreciated!...
              03-06-2024, 12:26 PM
