Hey y'all got a problem with a kdl26ml130 Sony bravia. At first I thought the IR sensor was bad on it bought a replacement still same problem. Began testing ir board for voltages every resistor and capacitor tested in the 3.3v range, a couple half that. What I did notice was a few chips on the mother board (main/digital) by the connector that were reading ol but have no clue what they're rated. When the schems say its a short chip, does'nt that mean it's just a jumper wire basically? The chip has a O on it, also when my meter probe touches it and the one below it the channel on the set changes. Just curious as to whether I am in the right area here is an image of the pin connections from the manual key and the IR board to the MB chip 3267 I believe is the culprit and as I said when touch probe between the two the set switches channels. Also component 3264 only measures 0.82v schematics parts list it as a 0 uh(micro Hertz) ferrite should it also measure the 3.3v standby. That's right ain't it? Any helps needed and appreciated. Can't load from tablet will load from laptop when editing, in a few moments...
sony bravia kdl26ml130 no IR remote signal at MB connector
Tags: None
Re: sony bravia kdl26ml130 no IR remote signal at MB connector
"0 uh(micro Hertz) ferrite should it also measure the 3.3v standby"
Zero micro Henry not HERTZ? Where did you get the 0uH from? Ferrite bead resistance between the two terminals of the ferrite will be very low, usually <1 Ohms or so.
How about up load some good clear pictures of what you are probing and the diagram you are using?
"The chip has a O on it, also when my meter probe touches it and the one below it" What is the 'one below it' ? It? I have no idea what you are trying to say.Last edited by budm; 07-30-2015, 05:28 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
"The chip has a O on it, also when my meter probe touches it and the one below it" What is the 'one below it' ? It? I have no idea what you are trying to say.Comment
"The chip has a O on it, also when my meter probe touches it and the one below it" What is the 'one below it' ? It? I have no idea what you are trying to say.Last edited by manstoblame; 07-30-2015, 05:53 PM.Comment
"0.87 an ohm" so it does not have open circuit so the part is OK, 0.87 is probably your test lead resistance..
< is the less than symbol not greater than.
> = greater than.'Never stop learning
https://drive.google.com/file/d/0B_E...ew?usp=sharing
I know its been a long time since I have been back to this post.
Anyone willing to help will have to spend a little time looking so much trouble trying to get something up to show what I am talking about that I did not have a chance to point out things with arrows sorry. Links are google drive hope you all can view. CN**** is where the manual controls and the remote IR also connects buttons work remote wont.Comment
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... -
by TomyleeHi everyone,
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the... -
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
from what i read online it looks to be an emmc issue…
i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
i took out the board and say an samsung 16gb emmc
i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM -
Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
Channel: Schematics and Boardviews
10-16-2024, 05:15 AM -
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM - Loading...
