Hello everybody!
I have a Panasonic TH-42PE7U 42" Plasma TV that died yesterday. The unit was manufactured October 2007. When turn the power on, I hear a few clicks - I'm assuming this is the relays energizing. When I press the power button on the front of the unit, the red LED is solid red and does not blink. The remote does not work - the unit does not respond to turning it on, or off. If I press and hold down the power button for a few seconds, I hear the relays click (off?), then back on a moment later.
Anyway, I was able to find the TH-42PE7U service manual from this site. I removed the back panel and checked the following so far:
Power Board - TNPA4221 AK
1. Verified that 120V was coming in on the line across P9.
2. Verified that fuses F401, F402, F403, PR401 and PR601 are intact.
3. Verified that probe location ZH150 (at diode D420) shows a peak voltage of about ~390V when I initially plug the unit in, then goes down to ~160V and maintains that voltage.
4. Q406 does not show a dead source between the source/Gate, drain/gate, or source/drain.
5. PR401 shows continuity.
6. I measured P11 and P2... Vsus = 0V.
7. I tried measuring across P11 and P2 again with the wires to SC2 and SC11 disconnected. This yields Vsus = 0V.
This TV does not have a blink code at all. I was hoping for *some* quick indication with the LEDs, but no dice. Where do I go from here? Any help would be greatly appreciated.
Thank you,
Thomas
Thank you,
Thomas
