Panasonic tc-p50s30 su,sc,ss repair help
  • bman4
    • Jul 2015
    • 210
    • canada
    I have a TXNSU1MNUX Panasonic SU (TNPA5336AM) that has a sigle top buffer ic shorted,
    you can actually see a tiny hole on it, this failed buffer ic resulted in failure of sc and ss.
    Do i need to just replace the buffer ic or is there other smd's that need replacing?
    The sc is shorted from sc2 upper pin 3 to ground screw.
    The shorted fet/diodes on sc
    2x:rfn20 ns3sw
    3x:rf1501 ns3s
    1x:rfn10 ns3s
    The ss has a shorted center pin to ground.
    The shorted fet/diodes on ss
    2x:rf1502 ns3s
    The ss also has the top brown cap 220v 120uf with residue on top unlike the sc,
    any recommendation on replacement?
    Im just gonna order it now and replace it while i can i cant afford a tester yet.
    Is there any other smd's that i gotta replace such as the repair kit you can buy?
    For me to order the repair kit is a waste of money because they are not all faulty.
    I just need to confirm before i order so evrything comes in at the same time.
    I want to thank you all for the opurtunity to joint the community to learn.
    sincerely,
    bman4
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p50s30 su,sc,ss repair help
    2x:rfn20 ns3sw
    3x:rf1501 ns3s
    1x:rfn10 ns3s
    2x:rf1502 ns3s
    sincerely,
    bman4
    kinda strange you find all the SMD diodes shorted on both the SC and SS but no IGBTs? You sure you know what you're doing? Ever removed and replaced a panasonic buffer IC before? I know I have not but getting them off without damaging the tracks is almost impossible.
    By the way pin 3 SC2 is gnd, ,so gnd-gnd = lead resistance of your meter
    and , center pin(pin 3) on SS11 also is gnd so you know already what that should read.
    I think, stop, take a breath , read a bit about some basics, get the manual, study the block diagrams and the schematics for the boards you refer to first.
    'm also going to assume you check those diodes wrong, they are common cathode and dual anode meaning if you measure across the 2 legs they'll appear to be shorted, but the tab to either of those legs will be like a diode , if it's good.
    So, good way for us to get back to fixing this broken TV.
    step 1, tell us what happened symptoms, how many blinks - I'm guessing we have 7
    step 2. forget about that suspect cap on the SS but feel free to upload pictures using advanced , manage attachments, no bigger than 2000x2000. Caps in these are high quality longlife, and this is a relatively young TV.
    step 3. check across the 2 pins at SC2 the resistance. If it's over 300k ohms and into meg ohms then the SC could be ok, in which case
    Step 4. Isolate the su/sd from the sc ie the 3 connectors , 2 on the sd, 1 on the su. now remove the bolts that gnd the sd/su to the sc, they will be inline with ose other white connectors, could be 4 of them or even 3 but make sure no gnd bolt is left attached . they refer to these as Vfg or floating gnd because it's gnd with respect to the cct on the SC not chassis gnd. That's why they attach to metal posts on the SC.
    Right, step 5. the SD/Su buffer isolation, SC50 jumper test. this will prove if 7 blink is SC or not. With the above disconnected but everything else connected normally, on the SC board, a small white connector SC50, 2 puins they need to be shorted together. Now, turn the TV on, if all else is good and you found no short at SC2 then the TV will turn on, no error blinks. If it shutsdown with 7blinks then the SC will be also faulty.
    I am assuming you do have a 7 blinker of course.
    other notes, clean up all gnd pads on the sc , check the ss too, replace those mounting bolts with normal bolts with washer set. The ones Pansonic used here work loose, causing bad earth on the Sc and ss board and arc, maybe the cause of these failing and/or the buffer board damage.
    Plenty sell these bolts on Ebay or Shopjimmy
    If the Tv passed with that SC 50 test, then assuming you're right I would not try buffer ic repacement unless you are very experienced in do that type of work. find a good used, or repair using someone like ModuslinkPTS orEbay but Modus can be trusted from what I read. I know being in Canada is goingf to make that expensive i suspect for shipping etc.
    If it's only SU, you may get away with using another 50" SU board say from a GT with heatsinks or the ST. Someone very recently used st30 su in a s30, try to doi a search on your tv model, bound o get plenty of hits as they commonly fail SC boards, buffers not as much. i did a similar model with shorted sc which needed 4 transistors, buffers survived, screws were loose and burn marks.
    Also, better tell us how you have checked the sd and su boards to know if they're good or bad. If there's a hole in an IC that's obvious but usually no visual clues in a lot of cases requires ohming it out.
    • bman4
      • Jul 2015
      • 210
      • canada
      I though one was atleast a fet from a ebay ad, i just rechecked all dioes.
      Ive been trying to find the sc 50 jumper, i dont think my sc board has one.
      The reason i though the ss was dead because i pulled the ribbion cable jumpers and i was able to get it to stay on with no picture or blink code.
      i tried some more test when trying to find sc50 so i just pulled the ribbion cables again, this time it wouldent come on without the ss ribbion cable disconnected and gave me a 8 blink code from orginal 7 indacting ss.
      Im new with a meter,i have just been just checking the 2 legs!
      Ive been practicing with a old computer mother board, i was susccessful at removing and re placing smilar smaller ic such as audio ic so im prety confidant,if anything ill buy a new one.
      Im not going to remove the buffer ic with just a soldering iron but with a reflow gun and preheater.
      It's been awhile,i gotta pull the tv from storage,ill get back to you with updated test's.
      sincerely,
      bman4
      • tw2005
        • Oct 2011
        • 6458
        well I'll just warn you that panasonic use a thermal silicone sealant / adhesive and it's run under the IC and all through the legs. I managed to practice on some dead boards and after 2 fail attempts manage to work out a way. If you attack it straight up with heat you may be disappointed if any of that silicone hangs on especially the legs as those tracks lift real easy. there's a lot of pins there.
        i found acetone helped breakup the silicon, wooden tooth picks to gently rub it away, then very carefully sliced the legs hard against the casing but careful enough not to slice through the board or some tracks may get cut.
        . This allowed me to keep working the acetone into it and then gently twist the ic body off leaving the legs behind and then kept working the acetone in, then very carefully used an iron to desolder the legs. The acetone definitely changed the properties of the silicone and it ccrumbled easier but won't dissolve it.
        Ricosavy has a post which I added some pics to and flocko has just got in on looking at ic replacement, he may be better atgiving tips but given how rare these boards are tofind and that they can be repaired the core is quite valuable at this point. otherwise one mistake and you're looking for a board , but hey, you know what you can do but if you have any other panasonic buffers to practice on first I would start there.
        Now back to the boards. All those items you list are 100% fast rectifier diodes.
        SC50 I'll find it for you if you hang around for a bit. I think you need to try that first.
        I'm sure i'd be happy if i discovered i only needed 1 board as opposed to 3.
        I think some manuals and guides would help you too understand the blink codes and what happens with what disconnected
        • tw2005
          • Oct 2011
          • 6458
          right , you should be able to just locate in this pic.
          the training guide not exact model but very closely related St30, page 88, check that out for the SC50 test, important those Vfg bolts are out, someone did report trying this with them in and fried the buffer boards.
          There's also a 7 blink procedure, a guide on what blinks are expected with things removed, resistance checks for the sc,sd,su, etc,etc.
          give the sc50 test a shot and if it passes, follow up with resistance checks on the Sd,su although sounds Su is shot with a hole.
          and then you may be lucky enough and just focus on getting a SU sorted and should be back in business
          Just check and double check you've reconnected anything you've previously touched. Lost count now the number of times a lead is missed and just throws a spanner in the works fault finding with an unknown variable.
          • bman4
            • Jul 2015
            • 210
            • canada
            I just tried with the su an sd boards competly out and now i get the 8 blink.
            I tried again without the ribbion cable to the ss a sc and bottom jumper and my power supply sounds kinda weird and would not light up at all, im letting it sit for a bit to get cleared.
            Wow the sc 50 is right in front of me i was looking for 2 bare pins.
            Everything tested fine now that i tested right but the sc was a 190 ohms and riseing on the tester set to 200k.
            Do i put a hardrive jumper in then plug it in or plug it in and put the jumper in?
            • tw2005
              • Oct 2011
              • 6458
              read the guide first. but have tv off, set it up with evrything connected correctly but sd/su connectors removed, 4 vfg bolts removed, short sc50 , hdd jumper may fit, I have a small alligator clip I can get half the clip to sit across the sc50 pins and the other half outside the case and just having it clamped like that usually shorts those pins, then just power it up and se if it stays on. then shut down and investigate buffers. If it fails and still has 7 blinks Sc is also bad, anything else well we'll see but I'm nearly out for time nee to hit the sack.
              also if sc20 is disconnected it triggers 8 blink, can't assume just because you have 8 blink SS is bad. read the trainer.
              • tw2005
                • Oct 2011
                • 6458
                need to now if 190 in 200k means 190k or 190 ohms but that connection can read in megohms. I don't like $10 meters, hope you have something reasonable , definitely worth investing in a good autoranging meter like a fluke, even a basic one which is all i have.
                • tw2005
                  • Oct 2011
                  • 6458
                  Even if the SC bad, it's already dead so doing this will either prove good or bad any way. I'm hoping it's good and just a bad buffer.
                  if SC2 was dead short that can cause locked solid LED or 14 blinks too.
                  • bman4
                    • Jul 2015
                    • 210
                    • canada
                    I have a pro teck d946,up to 1000v dc and 750ac.
                    I was going to use just the 200 ohm setting but it has an ajustable pot so i just figured 200k is the same, ill try again on the 200 setting.
                    • bman4
                      • Jul 2015
                      • 210
                      • canada
                      Okay the tv came on with a green light but the sc made a weird buzzing noise,i did torque the screw pretty good, no smoke so that a plus.!
                      The buzzing is comeing from the upper portion of the sc, it seem's to be a upper dioed or transistor.
                      I re torqued the screw a couple time to clean them up but still buzzing
                      • tw2005
                        • Oct 2011
                        • 6458
                        Okay the tv came on with a green light but the sc made a weird buzzing noise,i did torque the screw pretty good, no smoke so that a plus!.
                        yeah they can, could be loose or maybe because no load , either way the rest of the tV should be fine, just work out if just SU is bad or both sd/su but very recently there was a 50s30 bad Su , sc good.
                        I'd only check these with a meter, don't try running with just one board just in case something gets damaged, not worth the risk, hard enough to get parts these days with panasonic getting out of plasma Tv
                        I have to go, have a read , I find those trainers really interesting
                        • bman4
                          • Jul 2015
                          • 210
                          • canada
                          Thank you for your help tw2005.
                          Have a wonderful day!
                          sincerely,
                          bman4
                          • bman4
                            • Jul 2015
                            • 210
                            • canada
                            Do u think i should just replace all upper smd diodes and fets just for the hell of it.
                            Im thinking that the upper buffer failure caused this because it's only in the upper portion and maybee the component is on it way out.
                            I have a stethoscope and could try to narrow it down!
                            • tw2005
                              • Oct 2011
                              • 6458
                              no not really. get the TV running first it may quieten down once it's all back and running
                              • bman4
                                • Jul 2015
                                • 210
                                • canada
                                Understood!
                                Just got home,i fired it up and it did quiet down for a second,weird.
                                Im just going to order the screw's and the buffer ic.
                                I did read the whole buffer ic replacment thread and someone mentioned a silicone disolvent,ill look for one that's safe and effictive.
                                I look around for some more guides on how to remove the ic properly.
                                Now im getting a 8 blink error code without sc50 jumped when i orginally had 7 can't 100% confrim.
                                Dose this error refer to bad buffer, when i looked it up i came to a conclusion that it is failed ss, possibly because the ss goes to the panel just like the buffers.
                                  8 blinks is unusual, usually refers to SS board more than anything. Did you make sure to secure the link between SN/SC and SS boards?
                                  • bman4
                                    • Jul 2015
                                    • 210
                                    • canada
                                    Im pretty dam shure,im really good a ribbon cables.
                                    This error occured after i only did the unplug sc ribbion and ribbion rigth below.
                                    The set did fire with sold light then the next time it wouldent and i discovered 8 blink code witch led me to ss.
                                    Then i just tried unplugign the ss ribbion cable and got solid light again.
                                    • bman4
                                      • Jul 2015
                                      • 210
                                      • canada
                                      The green light is on the ss tho i guess ill have to wait to see what happens.
                                      • bman4
                                        • Jul 2015
                                        • 210
                                        • canada
                                        Can i mix a 50gt30 upper buffer with a 50s30 lower buffer?
                                        Is there a list of substitutes buffers anywhere?
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
