Hello, need some guidance. Tv powers on insignia lights up, backlight comes on. but no picture. These are know for there powerboard failure. Did general voltage check at harness' and should read as labeled, (see pic) Everything at CN101 (upper right) checks good except the 12.5 pins at 7,8,9,&10 were all reading around 7.2v. No abnormal resistance in wire. no burnt anything. Where should i go next?
vizio M470vse power board?
Tags: None
Re: vizio M470vse power board?
That is Regulated 12VDC output so it may have bad regulator or something, cannot tell until we can see the pictures of the bottom side of the board.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
OK, I traced out the 12VDC power supply section, this 12VDC is generated by the same power transformer T601 which also generates the 24VDC for the inverter board.
So for you to have only 7.2Vdc at the 12Vdc output pins, what DCV do you have on the 24Vdc output pins of the connector CN202? It should be lower than 24VDC also.Never stop learning
Ok My appologise. I used a different DVM and it seems as if 12v on cn101 and 25v on cn202 are good now. I checked again even with another DVM after that and the DCV read good on both connectors. Now it seems as if power board is ok. Double checked grounds and reference 3v all good. HMMMMM?????Comment
Since you do have backlights but no pictures on the screen, then the next place to look will be the fuse on the T-CON board, you need to find out if you do have either 5VDC or 12VDC on both ends of the fuse with ref. to the chassis GND when TV is turned ON.Never stop learning
Fuse is marked F102
http://assets.shopjimmy.com/media/ca....c03-top_1.jpgLast edited by TVRepairNoobie; 08-13-2015, 07:34 PM.Comment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
