17ips20 diagnosing
  • formant84
    • Nov 2016
    • 13
    #41
    Re: 17ips20 diagnosing
    Yeah I'm an idiot. I was testing them wrong. Turns out there are 4 duds.
    Not only that but I have some SMD LEDs that should be close enough to use. Gonna replace them now, I'll post the results.
    Thanks for the advice!
    • formant84
      • Nov 2016
      • 13
      #42
      Replaced the dead LEDs, powered on... Still no backlight.
      My guess is that my replacements couldn't take as much current as the originals and just instantly died. Got no more time to look at it today, might order the LEDs you linked in and have another stab at it during the week.
      Thanks again.
      • formant84
        • Nov 2016
        • 13
        #43
        Turns out the new LEDs are fine. They all flash once just as the voltage goes up to 190 but then go off straight away before it settles down to 115v. Any ideas?
        • formant84
          • Nov 2016
          • 13
          #44
          I Assume the LEDs are powered from a constant current source which isn't working, giving them a spike and then virtually nothing. I've tried measuring the current with my multimeter and it's either around 1ma or the fuse in my multimeter has blown :/
          • vinceroger69
            • Mar 2012
            • 6714
            #45
            have you retested all the leds again one by one? ive just fixed a strip for someone who had fitted some of the new leds on the wrong way anode/cathode as he didnt notice the pad size diffrence on the leds.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              have you retested all the leds again one by one? Ive just fixed a strip for someone who had fitted some of the new leds on the wrong way anode/cathode as he didnt notice the pad size diffrence on the leds.
              +1
              • formant84
                • Nov 2016
                • 13
                #47
                Yeah tested every one, and like I said they all flash on for a split second as the voltage jumps to 190v, so they're all working.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #48
                  Unfortunately leds flashing on doesn't really test the leds since it's only momentary. You may be better off testing them with an external power supply that you can current limit initially at 50mA or if you don't have a power supply then perhaps carefully with batteries.
                  There are threads on the Forum discussing methods.
                  • formant84
                    • Nov 2016
                    • 13
                    #49
                    Yeah like I said the first two times, I have tested all of the LEDs individually and they're all working.
                    • crt man
                      • Mar 2013
                      • 106
                      • England
                      #50
                      Hi
                      When you tested them individually, did they all have the same brightness?
                      I had a strip that when tested, they were duller than the others,
                      so there was a fault within that particular strip.
                      Alan
                      • formant84
                        • Nov 2016
                        • 13
                        #51
                        Hi Alan,
                        Well the ones I've replaced are a slightly different brightness, they aren't the exact right ones but I would have thought that as long as they light up and don't blow they would be okay. I guess this is not the case?
                        Do you think this is most likely to be the problem, or is it still possible that a fault on the power board is resulting in a shortage of current to the LEDs despite the correct voltage being supplied?
                        Thanks,
                        John
                        PS: Dick, sorry for being short with you, this TV is just winding me right up!
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #52
                          my guess its the leds you have replaced maybe upsetting the led ouput feedback circuit? are your replacement leds brighter or darker in brightness?
                          what tv is this your working on?
                          • formant84
                            • Nov 2016
                            • 13
                            #53
                            It's an ISIS 39227FHDDLED. Similar chassis to other cheap TVs with this vestel board.
                            The new LEDs are dimmer.
                            Is there any safe way to bypass the relevant LEDs to see if the backlight comes on?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #54
                              im not sure about bypassing them but this link is for vestel leds
                              http://www.ebay.co.uk/itm/VESTEL-VES...3D252304716100
                              not sure what postage is on these from ohm supplies
                              https://shop.strato.com/epages/62027...ts/LED11-Y6.01
                              • formant84
                                • Nov 2016
                                • 13
                                #55
                                Thanks, I'll give them a try when i can spare a few quid.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #56
                                  ive not tried either of these leds myself but they do say for vestel tvs i have used ohms supplies before for parts and they have always been good so do recomend there shop if postage is cheap 1.95 for 10 leds isnt bad i guess.
                                  • smiddy1980
                                    HELLLLLP
                                    • Sep 2014
                                    • 57
                                    • Scotland
                                    #57
                                    Hello, sorry for jumping on here but I have a 17IPS20 that the power going to the main board jumps from 23.3 down to 15 when the main board is plugged in, when I unplug the main borad the voltage sits at 23.3, I don't get any other voltage on the pins going to the main board, show I not see a 5v? do you think this is a faulty PSU or main board ?
                                    Thanks Guys
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #58
                                      The best way would be to force on the psu by itself and place a load on the psu outputs and see if its ok and the voltages stay stable under the correct load
                                        Surface Mount Fuses Fundamentals Datasheet
                                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                        10-07-2024, 06:07 AM
                                      • Sik_6ty_Sixx
                                        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                        by Sik_6ty_Sixx
                                        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                        02-18-2025, 05:06 AM
                                        How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                        by sam_sam_sam
                                        About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                        Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                        12-14-2023, 07:45 PM
                                      • alltvrepairs
                                        Vestel 17IPS20 power supply Q301 runs too hot
                                        by alltvrepairs
                                        Have just repaired this power supply after 4.7pF 2kv cap burnt.
                                        Replaced the following:
                                        U300 FAN6300
                                        Q301 8N60C
                                        R321 10R
                                        R311 10R
                                        C312 47pF 2KV
                                        All Supplies are now fine and TV works great however noticed that the Mosfet is running too hot that barely can leave finger on heatsink for a couple of seconds. I have left TV ON for 18Hrs straight and still works but I know something is not right.
                                        Usually a faulty snubber circuit causes this issue. Any known remedies for this common power supply?
                                        05-02-2022, 01:46 AM
                                      • acedogblast
                                        Power supply for main amp blows fuses after replacing filter caps.
                                        by acedogblast
                                        Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                                        I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                                        I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                                        02-27-2023, 05:11 PM
