17ips20 diagnosing
  • layad
    • Nov 2011
    • 244
    17ips20 diagnosing
    hello guys
    i have led tv which has 17ips20 psu , the tv is completely dead , no lights at all, i have checked the all the diodes, they are all ok, all fuses are ok, anyone knows how to test Q301? the tv is jvc le-40dg51j
    thanks
  • zwarder
    • Oct 2013
    • 46
    Re: 17ips20 diagnosing
    There are kits available to repair
    http://www.ohmsupplies.co.uk/KIT377-...D13-REPAIR-KIT
    Probably pick up a second hand board cheaper though
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Normally there is a leaky not shorted diode right next to the filter caps. Remove it out of circuit and check it for continuity in both directions common issue on these boards. If the transistors fail they will blow the fuse.
      • crt man
        • Mar 2013
        • 106
        • England
        Sorry Reece for hacking the thread,but I got a Hitachi
        40 inch Led from somebody's garden with the above PSU.
        Which is the leaky diode you mention,as there is no shorts
        on the FET's and the fuse is fine.
        I cannot see the diode you mention or I'am I just going
        senile with old age.
        Thanks Alan.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          reece has a good video about this board not sure if you have saw it
          https://www.youtube.com/watch?v=x7vnoqcTbQM&app=desktop
          • crt man
            • Mar 2013
            • 106
            • England
            Hi
            Yes I have seen it but this has not blown up,
            and the are no obvious shorts.
            I assume it is the leaky diode he is talking
            about in P3
            Alan
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              im sure reece will reply when he sees this thread and advise you on the diode location
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Cheers Vince, also what is the set doing totally dead ? You should check ehat voltage you have on the secondary diodes first see if you have 12v at the lower down ones then 12-128v at the ones near the top. If so then psu is good.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  If I may inject here....I have found that analogue meters detect 'leaky' semi-conductors more readily than digital meters. I have a trusty analogue on my workbench for testing semis
                  • crt man
                    • Mar 2013
                    • 106
                    • England
                    Sorry Reece, I was told set did not work,
                    as it had been standing in the rain I did not plug it in.
                    Just plugged it in and led changes from red to blue
                    but screen is black and no sound, I do not have the
                    remote so it could be on an external source.
                    Alan
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Well the Psu is good then, you have an Led failure probably. Watch this video:
                      https://m.youtube.com/watch?v=RxwdC7V5Ue0
                      Please verify if you have backlight or not, if you do not check the Led voltage, if that is good take the panel apart and check the backlights as shown in the video. Be very carefull with the Lcd screen and its attached Pcb they are easy to break and wont be fixable if so. Keep us updated
                      • crt man
                        • Mar 2013
                        • 106
                        • England
                        Reece, the backlight is out i hooked up a free view recorder
                        and it switched to the scart.
                        There was sound, and when turned to the window
                        an image was visible
                        The voltage for the LED's was 119 on positive and 11
                        on negative.
                        I have bought some Nos LED's from Ebay just waiting for
                        them to arrive
                        Alan.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Wait on start up does the voltage go to about 170 or so then go down ? If it stays at 119 your Psu/driver is faulty.
                          • crt man
                            • Mar 2013
                            • 106
                            • England
                            At start up the power goes to 190 before
                            dropping back to 119 the negative goes
                            to 24 then drops back to 11
                            On standby the voltage on the positive drops
                            to zero and the negative stays at 11
                            Alan.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Yes then you have a backlight fault then, the Psu is fine if it goes up then drops. Take the panel apart and test the Leds as shown in the video.
                              • Leslie W
                                • Jul 2016
                                • 7
                                Hi Guys
                                Hitachi 42hxt12u with Vestel 17ips20 23145840 problem.
                                TV made a crack noise and now no picture. No backlights but I can see menu with torch.
                                Audio working and can change channels and sources.
                                LED output from PSU is 117.7 return 8.3 when turned on - it does not go to 170 or 190
                                Is this a psu or a led problem? Why arent the leds lighting if I have 118 volts for the 36 x 3.3v vor the leds?
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Unplug the Leds and check again, use chassis ground. Sounds like a Psu problem to me if it stays low. Also thats not enough for the Leds that voltage its enough to complete the chain but only light them dim.
                                  • Leslie W
                                    • Jul 2016
                                    • 7
                                    Hi Reece
                                    Thanks for your help, please bear with me I am just a beginner.
                                    Why does the led voltage start at 160+ then go to 118 if 36 x 3.3 leds = 118 volts ?
                                    with the leds unplugged voltage is 117.6 and zero on return
                                    Les
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Its part of the Pwm circuit, starts at higher voltage to start the strings but low current, the it lowers and increases the current to maintain proper brightness whilst the Pwm is working. Your Psu is faulty in your case.
                                      • Leslie W
                                        • Jul 2016
                                        • 7
                                        Thanks Reece
                                        Just ordered one from ebay.
                                        If it works I could send you the old one.
                                        Cheers
                                        Les
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • Sik_6ty_Sixx
                                          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                          by Sik_6ty_Sixx
                                          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                          02-18-2025, 05:06 AM
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • alltvrepairs
                                          Vestel 17IPS20 power supply Q301 runs too hot
                                          by alltvrepairs
                                          Have just repaired this power supply after 4.7pF 2kv cap burnt.
                                          Replaced the following:
                                          U300 FAN6300
                                          Q301 8N60C
                                          R321 10R
                                          R311 10R
                                          C312 47pF 2KV
                                          All Supplies are now fine and TV works great however noticed that the Mosfet is running too hot that barely can leave finger on heatsink for a couple of seconds. I have left TV ON for 18Hrs straight and still works but I know something is not right.
                                          Usually a faulty snubber circuit causes this issue. Any known remedies for this common power supply?
                                          05-02-2022, 01:46 AM
                                        • acedogblast
                                          Power supply for main amp blows fuses after replacing filter caps.
                                          by acedogblast
                                          Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                                          I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                                          I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                                          02-27-2023, 05:11 PM
