Soniq E40W13C-AU TV Stuck on standby
  • zantesu
    • Jul 2015
    • 27
    Hi everyone
    Attempting my first ever LCD/LED TV repair. The problem is that the TV has power but is stuck on standby. When the power button on the TV or the remote is pressed, there is no response. The LED at the front of the TV just stays red and doesn't blink or flash or do anything else.
    I opened the back of it apart and saw no visible sign of the typical capacitor faults discussed in other threads; bulging, leaking etc. However, I decided to replace all the capacitors, except for 2 (The big one and the second biggest one) because I'm still waiting for it to be delivered, with panasonic, rubycon and nichicon ones (Low ESR where appropriate).
    I checked the voltages at the terminal connector to the mainboard, before and after the capacitors change and the results are the same.
    12 V ~ 12.4 V
    12 V ~ 12.4 V
    5 V ~ 5.1 V
    5 V ~ 5.1 V
    5 VS ~ 5.0 V
    STB ~ 5.0 V
    ON/OFF - 0V
    ADJ - 0V
    From these results I am assuming the issue is with the mainboard. I try finding another mainboard online but no luck. There's no schematic as far as I can tell, so I'm thinking of trying to fix the mainboard myself.
    Can anyone please point me in the right direction on where to start my diagnostic of the mainboard? Which are the usual components that fail?
    I try doing a bit of diagnostic myself and these are my findings:
    1) All caps seems to be working fine under load (but I might replace them later just to be safe)
    2) Tracing where the signal from the IR goes when I press the power button on the remote
    Refer to the Attached picture
    When I press the power button on the remote control the voltage at the IR terminal connector on the IR input pin changes (I think from ~5 V to 4.6 V from memory). I did a continuity test and found that the signal from that pin goes to the two SMD components in the picture I attached before it goings into the big Chip. However, the white looking component seems to fail the continuity test. The voltage change does happen on the left side of that component when I press the power button on the remote but there is no voltage change on the right side. I'm not sure what that component is to perform a proper test on it. Does anyone know? Thanks.
    3) From visual inspection of the photo (I have attached this photo as well) I took of the mainboard, I also found that one of the Voltage Regulator the BM1117-ADJ looks discolored compare to the rest of the components on the board. Is this normal? or is it burnt?
    Any help would be much appreciated. Thanks
    Best Regards
    Max
    Re: Soniq E40W13C-AU TV Stuck on standby
    On/off - 0v: Backlights ON/OFF
    ADJ - 0v
    : Dimming Control
    So you are missing two signals. It may be hardware or firmware.
    What you can do is you MUST remove those two signals wires that go the main board first then use one resistor (500~1K) between that ON/OFF wire and the 5VS, and another same value resistor between the ADJ wire and the 5VS.
    If the other sections of the main board are OK, then you should be able to see the pictures and hear the sound an all other functions, if not then you have more that just two missing signals problem on the main board.
    • zantesu
      • Jul 2015
      • 27
      Cheers thanks budm, I will try that and let you know the results.
      • zantesu
        • Jul 2015
        • 27
        So I did what you said, and the backlight and screen turned on (and stayed on). However, nothing came up on screen.
        It seems I'm still stuck on standby because the red LED at the front of the TV did not change; it just stayed lit up the whole time even though I was pressing buttons on the remote and the controls on the side of the tv.
        I also measured the voltages across that discoloured voltage regulator (BM1117 - ADJ) and these are my findings.
        Assuming pins are numbered left to right:
        Between GND - Pin 1 = 141.4 mV
        GND - Pin 2 = 0.790 V
        GND - Pin 3 = 5.18 V
        I also measured the other voltage regulator (BM1117 - 3.3)
        Between GND - Pin 1 = 0V
        GND - Pin 2 = 3.295 V
        GND - Pin 3 = 5.17 V
        Not sure if the both info would help. What should I look at next?
        • CherryNOD
          • Jul 2015
          • China
          Hi, my name is Cherry. I am new here. Nice to see you. I am from China. And now I am working in an electronics company named NOD Electronics.
          • zantesu
            • Jul 2015
            • 27
            Hi I think you posted this in the wrong thread. There's a welcome thread for new members.
              "Between GND - Pin 1 = 141.4 mV
              GND - Pin 3 = 5.18 V"
              So you have 5V at the input pin, and 0.79V at the ADJ pin, so if the IC is OK then you should have .141V +1.25Vref = 1.39VDC at pin 2, so you do have bad regulator since you are getting only 0.79VDC. You should take the resistance reading (no AC to the TV of course) between pin 2 and Ground to see if it shows low resistance, it can also have bad filter cap that is connected to pin 2 so you need to check that also.
              • zantesu
                • Jul 2015
                • 27
                Hi budm, thank you for your assistance. I measured the resistance as you have suggested and here are the results:
                Voltage Regulator 1 (shown in picture 1)
                Assuming pin number from left to right.
                Between GND - 1 = 0 Ohms
                GND - 2 = 341 ohms
                GND - 3 = 4 Ohms
                I have also checked the capacitor, with a multimeter set to ohms, that is connected directly to Pin 3 and it seems to be charging and discharging fine.
                Voltage Regulator 2 (shown in picture 2)
                Between GND - 1 = 102 Ohms
                GND - 2 = 454 ohms
                GND - 3 = 1k Ohms
                So because of these results are they faulty?
                If so I can't seem to find any supplier in Australia for the BM1117 series, can I use the LM1117 series instead?
                Their datasheet:
                BM117
                LM1117
                They both have similar specs except the LM1117 series has a max output current of 1.5A.
                  "Between GND - 1 = 0 Ohms
                  GND - 2 = 341 ohms
                  GND - 3 = 4 Ohms"
                  This one does not look right, it is showing that the input pin has only 4 Ohms of resistance. Is this the one that has pin 2 output of 0.79V but pin 3 input pin has 5V input?
                  I would remove it and then do the resistance testing again on the pads of the board where the IC was soldered to see if the low resistance will go away.
                  Either one of those two will work as long as they are adjustable type.
                  • zantesu
                    • Jul 2015
                    • 27
                    GND - 2 = 341 ohms
                    GND - 3 = 4 Ohms"
                    No thats the other one. Below is the overall findings so far
                    BM1117-3.3 (voltage Regulator Number 1)
                    GND - 2 = 341 ohms
                    GND - 3 = 4 Ohms
                    BM1117-ADJ (voltage Regulator Number 2)
                    GND - 2 = 454 ohms
                    GND - 3 = 1k Ohms
                      GND - 2 = 341 ohms
                      GND - 3 = 4 Ohms
                      GND - 2 = 454 ohms
                      GND - 3 = 1k Ohms
                      OK, one thing for sure is that the one with 0.79V output on pin 3 is not right so I would replace it.
                      But the other one that shows 5.17VDC on pin 3 but it has 4 ohms to GND, that has to be error in resistance reading since @5.17V with 4 Ohms you are talking about 1.3A of current with >6 Watts of power dissipation! That has to be an error.
                      • zantesu
                        • Jul 2015
                        • 27
                        GND - 2 = 341 ohms
                        GND - 3 = 4 Ohms
                        GND - 2 = 454 ohms
                        GND - 3 = 1k Ohms
                        I think you're right I double checked it again with 2 multimeters and the results are:
                        GND - 2 = 341 ohms
                        GND - 3 = Increase / decrese in ohms (possibly due to the capacitor it is attached to?)
                          Good, go ahead and replace that ADJ LDO IC with the 0.79VDC output then. I would get more than one in case it gets damaged.
                          'GND - 3 = Increase / decrese in ohms (possibly due to the capacitor it is attached to?)' Can be due to some left over Voltage that the caps did not completely discharged.
                          It is good to always check when the readings do not make sense, you can use Ohms law to see that what you are seeing is impossible.
                          • zantesu
                            • Jul 2015
                            • 27
                            Cheers thanks budm. I've ordered the part and will update you on the result.
                            • zantesu
                              • Jul 2015
                              • 27
                              Hi Budm, thanks for your advice I replaced the ADJ LDO IC and the TV finally turns on. It behaves while no input is in but when I plugged in the chromecast, it behaves for about 5 second and then the image is distorted. Please refer to the pictures. Thanks
                              • zantesu
                                • Jul 2015
                                • 27
                                Sorry does anyone have any idea what I should test or have a solution for this problem? Thanks you.
                                  • 31287
                                  when it does that, do the osd menu's still work?
                                  • zantesu
                                    • Jul 2015
                                    • 27
                                    No the menu does not seem to work at all. The problem has evolved, if you can say that, so instead of bad picture, the TV just keeps on restarting. So it will turn on, picture is good, then restart.
                                    • zantesu
                                      • Jul 2015
                                      • 27
                                      I think I'll closed this thread as the original problem was solved. The TV is no longer stuck on standby and the fix was to replace a faulty ADJ LDO on the main board. Thanks budm for your assistance.
                                        • 31287
                                        maybe check the other regulators incase one is overheating
                                        infact maybe your replacement is bad because something is overloading it?
                                        • Michael Long
                                          No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          by Michael Long
                                          I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          Dead / No Power / No Standby Light results after power company had three
                                          consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                          After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                          09-13-2022, 06:55 AM
                                        • Loagz
                                          Soniq S55V14B-AU Stuck in Standby
                                          by Loagz
                                          Hi, I'm hoping someone can point me in the right direction....
                                          I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
                                          After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they...
                                          11-15-2021, 02:13 AM
                                        • samsonn
                                          Soniq S55V16A-AU stuck in standby
                                          by samsonn
                                          I've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
                                          I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting...
                                          06-28-2020, 02:33 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • Stunt
                                          Hp Laptop Stuck on Hp protected by hp sure start screen
                                          by Stunt
                                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                          screen that's it and stuck there. I left it until the following day and i still...
                                          09-02-2025, 01:51 PM
