I have a Element ELEFW327 LED with no backlight. I only see one board in the whole TV. I read where chip U11 can go bad giving results like this so I replaced it and still the same. I can see the picture using a flashlight just no backlight.
Element LED No Backlight
Re: Element LED No Backlight
Please read these and report the Voltage readings:
https://www.badcaps.net/forum/showth...327#post510582
https://www.badcaps.net/forum/showth...327#post466043Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Your readings do not have the result as these:
https://www.badcaps.net/forum/showpo...97&postcount=4
What did you use for GND?
Also what do you get on the diodes?
https://www.badcaps.net/forum/showpo...40&postcount=1Never stop learning
OK, how about the reading of that link to post #1 for the voltage son those diodes? i wonder if you may have the same problem as shown in that link.Never stop learning
The readings are high, that white connector with two pair of wires ( red, gray, red, gray) that go to the LEDs, Can you take the reading at each pin? So far it looks like you have open LED or open connection in the LED string (LED are connected in series like Christmas lights so if one goes open circuit then the whole thing will not light up.
And what are the Voltage rating of those two caps, one is next to the LED connector, and another one is close by?Last edited by budm; 07-23-2015, 10:28 PM.Never stop learning
We will need good clear pictures of the bottom side of the board.Never stop learning
The Cathode of the Diode that I marked in the picture is part of the Boost Converter circuit (youi can see SMD power MOSFET and the inductor right next to taht diode), so if you are not getting any DCV at the Cathode with ref to GND, then you have dead boost converter problem or it is not getting any input to feed the Boosted circuit, you will have to trace that out.
This is not going to be an easy tracing due to the board is double sided.
Pictures provided by SHOPJIMMY. http://www.shopjimmy.com/catalogsear...ement+ELEFW327Last edited by budm; 07-24-2015, 10:07 AM.Never stop learning
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by canadaboy25Hi all,
I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...-
by triplefourTCL 75S421
PSU BOARD: 40-L402H8-PWD1CG
it shows not even a flash of backlight when powering up.
but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
with mb connected, PSON... - Loading...
