Panasonic A Board repair
  • mike.k
    • Feb 2014
    • 6
    Hi, I have a Panasonic TH46PZ800A (2008) that is completely dead. No picture, no sound, no relay clicks, LED flashes or any other response on power up. Following the Panasonic flowchart for No Power/Dead Unit leads me to "Replace the A Board". I'm scratching to find a spare A Board (P/No TNPH0712[1][A]DA), new or used. Has anyone had experience with board level repair of this board or similar?
  • t5mustang
    • Aug 2013
    • 5
    Re: Panasonic A Board repair
    I have had several that went out after storm. Found the HDMI chip bad. Just remove the chip and see if set comes on. If it does.. you know it is defective. YES it takes a long time and you have to be careful but it does work.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • k370
      Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
      by k370
      I have a NM-A321 board that is dead, with no power at all.
      When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
      With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
      • +3VALW
      • +5VAUX
      • 1.2VSUS_PWRGD
      • 3VALW_PGD
      • 1.05VAUX_PWRGD
      Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
      The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
      09-23-2024, 11:57 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
