Best Source for TV Repair Kits Visio 0500-0612-0140
  • Ltank
    • Jun 2013
    • 776
    I need to know the best source for T.V. P.S. Repair Kits. Normally you don't need every part in the kit. Use what you need from it and keep the other parts for future use. At least you will have part numbers of common parts that fail.
    At this time I need one for a Vizio M550 SV P.S. 0500-0612-0140
  • Ltank
    • Jun 2013
    • 776
    Re: Best Source for TV Repair Kits Visio 0500-0612-0140
    P.S. has 169vdc. No Stby 5vdc. I found no problems with any capacitors, diodes, transistors, voltage regulators or Mosfets. EPROM? or one of the IC chips? I could not find a schematic. Any help is appreciated
    • retiredcaps
      • Apr 2010
      • 9271
      If no 5V standby, check the SMPS IC on the backside of the power board (it will be on the hot side). Google each 8 pin IC and see which one is the SMPS IC. Then measure the SMPS IC VCC voltage in wrt to GND. I'm guessing the VCC startup voltage is in the 14 to 16V range. Check capacitor that is connected to the VCC startup IC pin as well.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        BTW, I'm not circuit pcb designer/layout guy, but this LG power board seems pretty nice.
        In particular,
        - all the transistors, mosfets, bridge rectifiers are mounted on a heatsink
        - there seems to be adequate spacing between the above and capacitors so the capacitors don't get too hot
        - name brand Japanese United Chemi-Con capacitors (KY in cold side)
        - largeish board allows more spacing between components making component level repair eaiser
        I never thought I would see high quality name brand capacitors anymore in consumer TVs at any price. I'm also surprised that LG, a Korean company, didn't pick Samwha or some other Korean made/based capacitor.
          What is it not doing?
          Pictures supplied by shopjimmy.
          • Ltank
            • Jun 2013
            • 776
            I had 169 vdc across the main filter cap. T checked all the pins on the resonate controller 8 pin chip. No voltage on any pin. The customer was wanting it fixed so he told me to order board instead if trying to fix it. Vizio had one . I have to send it in for a core or be charged 50 bucks. There was no 5vdc. Completely dead
            • Lvsitano
              Asus X532FL 3.2V at source and gate
              by Lvsitano
              I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
              First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
              I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
              First...
              06-26-2024, 02:13 PM
            • dkneyle
              Onkyo DX-V500 Laser Disc Player - weird SMPS fault
              by dkneyle
              This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
              Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
              02-01-2022, 02:08 AM
            • abhishekkumar1902
              Huntkey HK340-72FP SMPS shut on load above 2 amps
              by abhishekkumar1902
              I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
              I have checked the following:
              1. All output caps are OK, and all output rails read correct voltages at no load
              2. All output diodes are OK
              3. NTC is ok
              4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
              5. No short in main switching MOSFET
              6. All other components...
              12-18-2022, 09:52 AM
            • madan1
              Mackie Th15 SMPS low Vout
              by madan1
              I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
              It is basically a smps with amp and some dsp.
              The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
              Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
              By the way, the ferrite core of L10 is broken,...
              02-16-2025, 04:15 PM
            • rewease
              Replacement for the Siemens Bakelite caps in an early 1980s SMPS
              by rewease
              There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
              Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
              Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
              09-17-2023, 12:53 AM
