ps50b451b2wxxu clicking not turning on
  • Blueeyes
    • Jun 2015
    • 60
    • Uk
    So got a Samsung and taken back off to check for visiable faults got nothing I can see but makes a clicking noise when you try to yturn on about every 2-4 seconds any ideas? The blurry picture is of two cylindrical things that appear to be cracked could this be related? Thanks in advance for your help
  • Blueeyes
    • Jun 2015
    • 60
    • Uk
    Re: ps50b451b2wxxu clicking not turning on
    After testing around found unplugging logic board allows TV to actually turn on and there's sound no picture but can use remote to turn it on and off
    • Hamie
      • Apr 2014
      • 1383
      How did the logic board become unplugged?
      Does the panel have any cracks? Even the smallest crack in the corner?
      • Blueeyes
        • Jun 2015
        • 60
        • Uk
        Nope no cracks and I unplugged it, with logic connected there was just clicking noise with logic unplugged there was sound and it turned on.
        • Hamie
          • Apr 2014
          • 1383
          In a darkened room is the panel glowing?
          • Blueeyes
            • Jun 2015
            • 60
            • Uk
            I can't test till tonight, (just moved in no curtains massive windows) but will update when I can should I test with logic back connected?
            • flocko
              • Nov 2012
              • 1121
              You have a short to the Vs, could be Y or X Sus board maybe Y buffer or power board ? disconnect Y and X see if it will turn on with logic board reconnected ? then try disconnecting X+Y one at a time to find faulty one, if it starts relay clicking with both unplugged the fault is on the power board, hope this helps Flocko
              • Blueeyes
                • Jun 2015
                • 60
                • Uk
                Appears to be ysus as with that unplugged turns on with sound but with y on and x unplugged same clicking problem
                • flocko
                  • Nov 2012
                  • 1121
                  Can you try with Y unplugged and X plugged in ? if it powers up then yes it the Y or Y+ buffer or Buffer would need to check ? Flocko
                  • Blueeyes
                    • Jun 2015
                    • 60
                    • Uk
                    Yeah it only power on when y is unplugged
                    • Blueeyes
                      • Jun 2015
                      • 60
                      • Uk
                      So best to check resistors first and try narrow down if its buffer or y or both
                      • flocko
                        • Nov 2012
                        • 1121
                        you will need to test the Y sus and buffers before jumping in an ordering things, you need to remove them from the set. do you have a DMM and know how to use it? can you tell us what boards are fitted (BN96-12390A is used in this model I think ?and LJ92-01691 buffer )?
                        • Blueeyes
                          • Jun 2015
                          • 60
                          • Uk
                          Yeah got dmm I'll go have a look at boards now believe it's that buffer and got a rough idea how to use dmm
                          • Blueeyes
                            • Jun 2015
                            • 60
                            • Uk
                            Boards are bn44-00273b and lj41-05905a
                            • flocko
                              • Nov 2012
                              • 1121
                              Need board numbers for Y Sus and buffer? BN44-00273B is the power board and yours is a BN44-00274 as I can see in the photo. test Y board for shorts across Vs to ground and check buffer ICs for shorts if you are unsure how this is done look on you tube, Tom has a how to test buffers demo on there and this will show you. Flocko I have just looked again and see your Y Sus is a Y+buffer combo these are hard to find and cost loads. you my wish to repair your board our get some one to repair it for you, I still need the number?to help you more
                              • Blueeyes
                                • Jun 2015
                                • 60
                                • Uk
                                Sorry my bad just realised I read 42" number not 50 is ybuffer along bottom of TV? I'll take a picture I get confused with plasma ones
                                • Blueeyes
                                  • Jun 2015
                                  • 60
                                  • Uk
                                  Logic buffer lj41-06244a bottom left, bottom right lj41-06245a y main lj41-05905a can't find y buffer only x buffer unless I'm missing it somewhere
                                  • flocko
                                    • Nov 2012
                                    • 1121
                                    The Y Sus looking in the back is big long board on the left with the panel ribbons going to it, you have taken a photo at the start, but cannot make out number. I am thinking it will be LJ92-0160 you will find this number along the bottom right of the board. As already said this can be a hard to find board and the cost is shown in the fact, I have repaired these in the past and will look up what it took to repair,I may also have one or two laying around my workshop some that I meant to put o eBay if they are the same
                                    • Blueeyes
                                      • Jun 2015
                                      • 60
                                      • Uk
                                      Yeah you're right with the board number lj92-01601a it says going to test for shorts now
                                      • flocko
                                        • Nov 2012
                                        • 1121
                                        So to test buffer ICs you will see two green resistor next to the (3)buffer ICs with your meter set to low OHMs check across them , OL on meter if good low OHMs Bad , check white plug top right on board black to ground meter set low OHMs pins 1+2 LO,pin 3 low OHMs,pin4LO,pin5 low OHMs,pin 6 OL this would show a good board,pin 1 being the pin nearest the end o the board , OL the reading you get when your leads are apart, and low OHMs when leads are touching , please do these checks and give me your readings
                                        • LGhost
                                          Samsung ue55d8000yuxxu turning on/off and clicking
                                          by LGhost
                                          Hello everyone! This is my first thread asking for help and I'm new here so please be nice
                                          I'm trying to repair a Samsung TV but not having much success so I've came across this forum and it seemed kinda nice and friendly. The TV is clicking on/off (relay) and I can't seem to put my finger on the issue. The image looks fine (since I can get a glance at the "Smart TV" logo when it boots). But it's just an endless loop of on/off. If I disconnect the mainboard from the PSU it stops doing the "clicking" sound but that's about it. I've already got a used mainboard...
                                          05-22-2023, 05:40 AM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • Sparklingx
                                          HP 450 g1 keeps turning on even tho shutdown/sleep
                                          by Sparklingx
                                          HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                                          09-23-2024, 12:34 AM
