Sharp Aquos - LC-52LE640U - Power Supply Error
  • wcsd106
    • Jan 2015
    • 57
    I am in the process of diagnosing the problems with a Sharp Aquos LC-52LE640U television.
    This television has been having intermittent problems since early 2015 with the Lamp Error counter reaching 5 and causing the TV to display the Lamp Error LED Blink Code until the lamp error counter is reset through the service menu.
    Last week, the TV again refused to power up. However, the LED code is now 2 long blinks, 2 short which, according to the service manual, represents a power supply error: Power supply error 2 (*2) UR+13V error.
    I have located a replacement power supply board, but I am hesitant to replace the power supply unless it could also be tied to the lamp error problem I've been experiencing.
    Any ideas?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Sharp Aquos - LC-52LE640U - Power Supply Error
    Have you actually checked the output voltages of the power supply, to see what they are like?
    -Ben
    Muh-soggy-knee
    • Terryfictv
      • Mar 2011
      • 124
      D7805 on the power board is shorted = replace with MUR460.
      • wcsd106
        • Jan 2015
        • 57
        Thanks for the replies. I haven't actually had a chance to crack open the case on this TV yet. Had a couple of those Hisense (Crap) tv's in on repair. Will be opening the case tomorrow and removing the power board to test.
        • wcsd106
          • Jan 2015
          • 57
          Power supply has been removed and is ready for bench testing.
          I have attached a picture of the PD connector and pinout.
          I know that normally you can turn on a power supply by shorting the PS_ON and 5VSB pins. However this particular board does not have a 5VSB. It has a STB, which I assume is standby, but the adjacent pin to the PS_ON is BU5V.
          Before I proceed, which pins should I focus on shorting to get this powered up?
          Thanks.
          Also, my first order of business was to check D7805 as suggested. With one leg of the diode removed from the board, the diode is testing as OK.
          • wcsd106
            • Jan 2015
            • 57
            Bench tested the power supply board today.
            The pinout was in post #5.
            I connected Pin 14 (PS_ON) to Pin 15 (BU5V) which was the only pin that had 5v on it as soon as power was applied to the board.
            With a switch connecting Pins 14 and 15, I get no output voltage on any pin except for P13 (AC Det) which shows around 3.3v, and pins 14/15 which are both at 5v. (switched on)
            • wcsd106
              • Jan 2015
              • 57
              Any ideas of where to check since I am not getting any voltages except for the 3.3v AC Det and the 5v standby voltage?
                How about showing good clear pictures of the whole back side of the TV so we can see all the boards, also the pictures of the whole boards?
                • Terryfictv
                  • Mar 2011
                  • 124
                  Check all the fat, hefty diodes D7806B, etc.
                  budm is right....send pix of whole boards.
                  • wcsd106
                    • Jan 2015
                    • 57
                    Here are the pictures, as requested.
                    If you need a closer shot of anything, let me know.
                    Seen is the unit itself, the TCON board, the Main board, and the Power Supply / LCD Controller board.
                    • wcsd106
                      • Jan 2015
                      • 57
                      Have checked all the hefty diodes. All are testing fine with my BK 5460 bench multimeter set to diode test. All are showing a voltage drop of around .4~.5 volts, infinite when polarity reversed.
                      Checked the two large electrolytic capacitors wired in parallel, they check out fine.
                      Going to check the other electrolytic capacitors tomorrow, but visually none of them look bad. C7500 & C7510 are in parallel and may have to come out of circuit for testing as my meter isn't getting a reading on either of them. There is a resistor across them that might be limiting my meter's ability to test them.
                      • CapLeaker
                        Leaking Member
                        • 8176
                        can you provide a better picture of the bottom left or the whole thing again of the power supply? I can't read anything, too blurry. The main board pic is blurry too.
                        • wcsd106
                          • Jan 2015
                          • 57
                          I will take some more photos in the morning and get them posted. I will use my other camera that will let me get closer.... boards may have to be shot in multiple pics to get the best resolution.
                            What DCV do you get between the two legs of those two main filter caps (47uF 450VDC) when you force on the power suppl? It should be more than 360VDC.
                            Pictures provided by shopjimmy.
                            http://www.shopjimmy.com/catalogsear...?q=LC-52LE640U
                            • CapLeaker
                              Leaking Member
                              • 8176
                              Forcing on the PSU, while all other boards are disconnected and see what you get is your best option.
                              • wcsd106
                                • Jan 2015
                                • 57
                                Bud,
                                When I force the power supply on, I am getting 405.99v DC read across the legs of C7800A and C7800B (The large 450v electrolytic filter caps) With the power supply in standby, I get a reading around 168v.
                                  So the PFC Voltage booster circuit is OK. So when you have all the boards connected back together you do not get the PS-ON signal?
                                  • wcsd106
                                    • Jan 2015
                                    • 57
                                    I will have to hook everything back up and see.. I'll leave my wire soldered to the board at the PS_ON connector so that I can connect my meter to it.
                                    I would assume it tries to power up, since the sharp V on the front of the tv flashes an error code when I hit the power button on the TV.
                                    Will give it a shot here in a few and see what happens.
                                    • wcsd106
                                      • Jan 2015
                                      • 57
                                      Curious though, If I measure from the negative side of the large filter caps to pin 1 or 2 (PNL12V) of connector PD (The panel voltage connector) I am getting about 13v AC at those pins, however if I connect the negative multimeter probe to one of the pc board grounding points (GP7006) for example that serves as board ground on the secondary side of the display, I only measure 9 volts AC.
                                      I was expecting DC voltage on that side of the board, and would definitely have expected the voltage to remain the same on the negative side of the filter cap and the ground point.
                                      It's almost like something is floating just a bit above ground on that end.
                                        Are you talking about the negative leg of the main filter cap? You only use that as the GND ref when you make measurement in the primary side, when you check the PNL12V is in the secondary side so you will use the chassis as the GND ref.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • timtrace
                                          Won't stay powered on - Sharp LC52LE700UN with RDENCA336WJQZ DPS-286AP power supply
                                          by timtrace
                                          Greetings - first post. I'm awed that a forum like this exists. It's a dream come true. I'm not even kidding.
                                          I've got a 13 year-old Sharp LC52LE700UN television that's developed a problem of powering itself off after 30-45 seconds. If I pull the mains cord and reconnect, it will come back on right away without so much as a button push...then turn off after 30-45 seconds.
                                          Service manual S37X3LC46E77U is attached to this post, as well as a front and a back picture of the RDENCA336WJQZ DPS-286AP power supply taken after completing my work.
                                          Each time that the...
                                          05-14-2020, 09:24 PM
