DP40142 Power Supply
  • RAMSELECTRONICS
    ATARI boy
    • Jul 2015
    • 48
    Re: DP40142 Power Supply
    Base to isolated ground is 14.95V
    • RAMSELECTRONICS
      ATARI boy
      • Jul 2015
      • 48
      C509 is very good. 22uf
      • RAMSELECTRONICS
        ATARI boy
        • Jul 2015
        • 48
        PC502 has no voltage input. so it must be something with Q203.
        • RAMSELECTRONICS
          ATARI boy
          • Jul 2015
          • 48
          gonna try jump on PC502 pin 3 and 4
          • RAMSELECTRONICS
            ATARI boy
            • Jul 2015
            • 48
            Changed mind.. I jump E and C on Q203 the PC502 pin 1 and 2 is low as .134v... umm pc502 should be bad.. gonna pull it off and check it out.. will back tomorrow.. good night.
            • RAMSELECTRONICS
              ATARI boy
              • Jul 2015
              • 48
              Ah... the PC502 opto is bad! short on the pin 1 and 2. replaced and opto is actived BUT... Q503 base is still 15V.
              I decided to jump with C and E on Q503 seem like 50% working the 24V output is 13V and 12V output is 8V.. ummm... Sound like the 12V and 24V have auto shutdown when something is short circuit. I am gonna disconnect the backlight to see what's happen.
              • RAMSELECTRONICS
                ATARI boy
                • Jul 2015
                • 48
                SHOOT! I found out the U101 has bad chip.. because PIN 16 has signal output. but PIN 11 has NO signal output. I already replace the chip.. oh boy! have to order the chip again.. but I am thinking to buy a PSU board for once. what do you think?
                It broken by the lightening.
                  Its may be time to buy the board, but if the TV was hit by lighting you then may have bad main board also.
                  • CapLeaker
                    Leaking Member
                    • 7977
                    Those lightning specials can be a real pain in the rear to fix. If it is economical to get a new board, I'd buy the board. If you can't get the board anymore and you need to have it working, you got to go fix it.
                    • RAMSELECTRONICS
                      ATARI boy
                      • Jul 2015
                      • 48
                      Alright, first I have to do my own power supply for 5V, 12V, 24V to connect it and to see if other boards are good then get new PSU if not then trash it.
                      THANK YOU FOR ALL YOUR INPUTS!!!!
                      ::END OF LINE::
