Lg 37lh3000 white screen issue
  • mr.tight
    • Sep 2010
    • 39
    Hello to all.
    I was hoping I could get some advice. I have just realised how much I depend on my TV now it's stopped working.
    It's an LG 37lh3000 and over 5 years old. When I changed the input selection to PC, the screen started to flicker for a few seconds, then turned white. I can still operate the menu, although can only just make out the text. Sound is still OK.
    It's been playing up for the last year, where it can take a while to pick up a connection, and flickered from time to time. I put this down to bad connections on the HDMI and never happened enough to annoy me.
    Anyway. Having looked around, I keep hearing the Tcon board is most likely the problem, although I'm struggling to find a replacement part. I have tried to reconnect the video cable going to the Tcon, and also the connectors going to the screen. However, I cannot access the connectors to the actual screen as it's enclosed within a mental frame.
    I have a nasty feeling I will need to buy a new TV, but obviously want to try everything else first including finding a new TCON.
    Does anyone have any ideas please?
    many thanks
  • mr.tight
    • Sep 2010
    • 39
    Re: Lg 37lh3000 white screen issue
    I've located the tcon board here for 30 pounds, does that sound OK?
    http://www.lcd-plasma-parts.co.uk/t3...n?search=26793
    The number I have, is UT-5537T04C36-998-2075669-00492-03
    There is also another code: T37OHWO2 VG
    Not sure what to do.
    • mr.tight
      • Sep 2010
      • 39
      I have ordered that part. I'll be sure to update in a couple days when it arrives. Fingers crossed. Far cheaper than a new TV
      • mr.tight
        • Sep 2010
        • 39
        Just reporting back to let anyone know that the replacement Tcon board fixed the issue.
        There is a certain chip that is notorious for failing.
          http://www.shopjimmy.com/catalogsear...lt/?q=T370HW02
          Probably bad GAMMA ref. Voltage IC AS15/19 series.
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
