I'm figuring there must be a way to do this. I can't imagine places like Moduslink and others having a thousand test TVs taking up shop space. Power supplies are easy, but what about main boards, Tcons, sustain boards, etc?
Is there a way to repair and test without a TV to test in.
------------signature starts here------------
Tags: None -
Re: Is there a way to repair and test without a TV to test in.
I would say Bud M would be the best to advise. I would think one would break each section of the TV down and find what needed to be powered to get just that board that you what to work. Bud M's site LCD TV and Monitor basic troubleshooting guide is a good way to start as that is on going. Of course different manufacturer do things in different ways so that is something one has to consider when repairing different TVs. -
I know I've been able to test many main boards on different TVs which used similar boards. I've also been successful testing main boards in larger TVs which use the same board, but different firmware. Sometimes that works but just doesn't fill the entire screen. I'm thinking it would be possible to remap the lvds to a different panel/tcon if the signals are universal. I'm sure I'd have to accommodate for voltage differences though.------------signature starts here------------
Yes, with an oscilloscope you can check LVDS signals and verify basic main board op, but no substitution for real test. Sustain boards can't be tested without the complex waveform generator that is the control board.
Power boards are the easiest and can be tested under load.
ModusLink to seem to test in live chassis - at least one photo on their website shows lots of TV chassis.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
What about remapping lvds to a different panel, assuming you had the data sheets and could determine which signals went where. Would that work, assuming the displays were the same size? My idea is to have an assortment of test boards which would connect between the stock lvds cable for the boards I want to test, and the stock lvds cable for the panel I want to test in. The board would just reroute the signal pairs to map them to the panel, and also make any necessary voltage adjustments.------------signature starts here------------
I would imagine that would simply take too much time to be worth it. Anyway, the LVDS signals will probably be of different formats (bit order, resolution, polarity, even/odd swap, etc.), even if they have roughly the same number of pins or similar pin order.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That's what I was wondering. Thanks.------------signature starts here------------
by chth96Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.... -
by khelaneHello
I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
Is there a way... -
by chronic519Hello.
GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
Found issue with a RAM block
Replaced, green lines gone.
Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
Used a good card to test and same results low errors 32+.
I am just search for some form of command to do a full test on the GPU.
I just ran the mats command with my good GPU and passed after roughly 40 min.
The repaired one, ran... -
by alltvrepairsHi,
i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
Appreciate your help....2 Photos -
by signal.questHi all,
I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...6 Photos - Loading...
