Sony NSX-46GT1(Google TV) 2 x error code
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony NSX-46GT1(Google TV) 2 x error code
    That is the board.
    I'm going to take some pictures.
    Ground at the LEDs circuitry, is the TVs chassy, right?
      No - the LEDs use a floating ground to balance current (external balancer using transistors), the ground is usually a few volts above the chassis.
        The Anode of the LED string is connected to the output of the boosted converter, the Cathode of the last LED string is connected to the Drain of the PWM MOSFET, the SOURCE pin is connected to one end of the current sensing resistor, the other end is then connected to the boosted converter ground return.
        The example shows 4 strings, two strings are connected in series to form one long string, so there are two long strings with two LED drivers.
        • tibimakai
          • Jan 2012
          • 3680
          OK, here are some pictures. Sun it was in an angle, sorry about the shadows.
          I have measured again the Vled by using (-) from a capacitor and Tom you were right, it measures 189V.
          LCD panel #, is the one Bud posted.
            Check the DCV between the two legs of C6801, set the meter to >200VDC scale, keep a close eye on the meter when you first turn on the the TV to see if your meter is fast enough to show >200VDC on the meter before it settles down to lower Voltage.
            The two LED string 1 and 2 do not look like to be connected in series as I thought after looking at the bottom side of the board.
            • tibimakai
              • Jan 2012
              • 3680
              Using Min/Max-Max, I have got 259.5V.
              So, it seems like LED issue after all, am I right?
                Yes, you have open circuit some where in the LED's string.
                • tibimakai
                  • Jan 2012
                  • 3680
                  There is a harness with a male/female connector coming out from the LEDs.
                  I don't know what that is for.
                  Two blue wires goes into one of he connectors and the other two wires, which are black goes to the other connector and they both are connected together.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    That has to wait a couple of days, since my back flared up.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      OK, I took it apart and to my surprise, the bottom right connector was fallen off, from the LED pcb. Maybe cold solder joint, or de-soldered from to much heat?
                      There is a top and bottom strip, which are basically made up from two half strips. Two wire connector, to each corner.
                      The back-light, turns on now and the power LED, stays green. Most likely, it is fixed. I need, to put it together.
                      Thank you, for all of your help.
                        Easy fix if so, thanks for the update.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          After putting together the screen, I have double checked that the TV it still works and it worked.
                          I have fully assembled the TV and it went back to the 2x error code.
                          Took it apart again and now, another connector has fallen off.
                          After soldering that back, tried the other ones and they seemed to be sturdy.
                          Finally put it together and it's working. But, I will have to take the front screen off, because it's not perfectly clean.
                            Thanks for the follow-up.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              My TV, would not update to the latest firmware(OTA only), but I have found a site, where it explains how to do it via USB. My version, it was 2.1 and the latest is 3.2(Honeycomb).
                              http://pastebin.com/GiLt8Dz2
                              • Junky228
                                • Jul 2013
                                Hey I was hoping I could resurrect this thread? There's a lot of good information here, but I need a little help. I have a NSX40GT1 too and when I hit the power button it will start to turn on (so the logo lights up, no backlight though, and if i shine a flashlight I can see the screen start to show the boot logos) however it realizes the backlight doesn't turn on and then turns off, giving me a 6 red blink error code [rather than your 2 blink code].
                                One thing that I was able to do was cut the BL_ERR (tiny orange wire) that goes between the power supply and the logic board and I connected the logic board's end to the chassis [leaving the end connected to the power supply floating. This seems to let the TV ignore the backlight error and I was able to verify that the rest of the TV works fine, just there is no backlight.
                                I'm sorry, I know this is a couple years ago, but what's with the resistor and wires on the back of the board? My TV's power board certainly doesn't have that... Would messing with that potentially help?
                                So you found that the LED strip had disconnected wires? Last I took apart my TV to try and get it working they looked solid but I'll admit i didn't check continuity on the joints.
                                Would anybody be able to help me figure out what the correct standby and operating voltages are supposed to be for the Dimmer, BL_on, and BL_err wires are supposed to be? Also are they supposed to be signals from the logic board sent to the power supply, or are they signals from the power supply sent to the logic board to tell it what's happening?
                                When referencing to the chassis ground the 4 pin connector to the LED backlight has ~130volts, both when in standby and when I power the TV on. The 5pin connector to the LEDs is around 3-6 volts on both wires (when referencing the chassis ground) and the little black connector that comes out of the panel has 20V on it.
                                I'm sorry if this seems jumbled, I can clarify if anybody can help me. Could anybody please help me figure out the proper voltages are and help me diagnose/fix this TV??? It functions perfectly (except for the backlight, when I bypass the bl_err code) I've been trying on and off for years to get this dang thing fixed....
                                edit: I can supply pictures/test-point voltages too to help explain, please, please just ask. I'm sorry if this is supposed to go in a new thread, I was just hoping that you guys might be able to help since this thread is about the closest I have gotten to solving the problem i think...I've looked through so many forum posts trying to gather info for this dang TV
                                  LCD LED TV Service Menu Codes
                                  ALL LCD LED TV SERVICE MENU CODES
                                  Service Menu Code with Board Name
                                  China Universal Board / Jumper Board Service Menu Code
                                  Changhong Ruba Service Menu Code
                                  Ecostar LED TV Service Menu Code
                                  Orient LED TV Service Menu Code
                                  Haier LED TV Service Menu Code
                                  TCL LED TV Service Menu Code
                                  Samsung LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  Videocon LED TV Service Menu Code
                                  Supra LED TV Service Menu Code
                                  Toshiba LED TV Service Menu Code
                                  Symphony LED TV Service Menu Code
                                  Veste/ LED TV Service Menu Code...
                                  10-31-2024, 03:58 AM
                                • GoodCapDude
                                  Sony XBR-75X940E intermittent 6 blinks error code
                                  by GoodCapDude
                                  Hi everyone. First post on Badcaps!
                                  I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                  09-20-2025, 06:07 AM
                                • Daren87
                                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                  by Daren87
                                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                  08-13-2023, 03:25 PM
                                • Carlos#2003%
                                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                  by Carlos#2003%
                                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                  02-15-2024, 07:52 PM
                                • reporter1979
                                  2 red blink code on old led tv Sony KDL-40W2000
                                  by reporter1979
                                  Hi all, the TV KDL-40W2000 was flashed by a lightning.
                                  Firstly I got the 3 red blink code.
                                  Following other threads I changed the power supply board and got always 3 blinks.
                                  So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                                  The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                                  What else can I do?...
                                  02-17-2023, 11:50 AM
