Sony KDL50EX645
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Sony KDL50EX645
    Been running this set for a few days since i got the repaired smps back from Sony Serv Center. Was working perfectly. Dead totally. No green LED, No Red LED. Nothing. Not getting PS-ON 3.3 volts from main board. Disc main board and jump pins 1-3 on smps. 12 and 24 volt rails come up.Have 3.3 volts standby on pins 1 and 2. Main board Digital audio port glowing red. I cannot find a service manual for this set anywhere.
    It did have access to internet while it was running.
  • ammarben
    • May 2013
    • 63
    • algeria
    Re: Sony KDL50EX645
    check main bord volage regulators
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      Re: Sony KDL50EX645
      I see two of them that look identical. They do not read the same when tested with meter.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Re: Sony KDL50EX645
        They are smd..to take them out of circuit can i use a normal iron?
        • tibimakai
          • Jan 2012
          • 3680
          Re: Sony KDL50EX645
          Put a blob of solder(join all of them), on the legs and heat them up all at once. Go back an forth on the tab and legs.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4958
            • New Zealand
            Re: Sony KDL50EX645
            Are they identical? Exact same part number? Check they are not being used as adjustable regulators.
            Photos would help!
            -David VanHorn
              Re: Sony KDL50EX645
              Before taking them out you should at least take the DCV readings of all 3 pins with ref to the chassis GND first, and also provide the P/N as printed on the bodies.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                Re: Sony KDL50EX645
                The new board from SJ arrived...the resistance readings on both voltage regulators varies greatly bwtween the old board and the new board
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Re: Sony KDL50EX645
                  Did the new board work? SJ is about the best place to get replacements...
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    Re: Sony KDL50EX645
                    Yes, the main board did restore operation.
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
                    • cheeky2
                      Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                      by cheeky2
                      For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                      See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                      01-08-2024, 05:56 AM
                    • joby91
                      SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                      by joby91
                      I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                      I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                      I found one chat about firmware on ************** forum but i cannot read the comments.
                      https://**************/forum/108-114100-1#880537
                      09-04-2024, 01:34 PM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
