capacitors question
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    capacitors question
    Hi all i have a bush 40inch lcd tv set,on my board there is a few bulging caps,not burst,do these need changing,as my set it taking forever to switch on,but ok when is.
  • sordids999
    • May 2013
    • 2155
    Re: capacitors question
    Yes they will need changing thats what is proberly causing your problem
      • 31084
      the 2 in the top right have burst.
      • Saltfrog
        • Jun 2015
        • 20
        Digikey or Mouser are good sources for caps. The bulging ones need changed for sure and although the others look good they might be on their way out as well. Don't let it cycle anymore as you can damage other components.
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          Thank you,be right on it,the recommendations for caps are they eBay or Amazon sellers ?
          I need
          1000 50v 1
          1000 16v 2
          470 35v 1
          2200 6.3v 1
          2700 16v 1
          If anyone can do me a deal,
          Thank you
            • 31084
            your in the u.k. so buy from CPC for free shipping.
            get panasonic FR series.
            http://cpc.farnell.com/
            and edit your list, you need to put the diameter & height.
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              diameter & height is that stated on the cap.
              or alternatively without me reopening and anyonec knows the board 17pw26-4,to advise me.
              • diif
                • Feb 2014
                • 6978
                • England
                I have a 17pw26-4 on my bench.
                1000 50v 16mmx25mm
                1000 16v 10mmx20mm
                470 35v 10mmx20mm
                2200 6.3v 10mmx20mm
                2700 16v 12.7mmx21mm
                http://uk.rs-online.com/web/ also offer free shipping.
                  Beware, there are several versions of 17PW26-4, so make sure to only order what's on YOUR board.
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    thank you,just looked on on ebay seller example ,470uf35V
                    10mm x 16mm x 5mm would they be the same ?
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      v.1
                        Do *NOT* order capacitors from eBay if you can avoid it. They are usually general purpose or cheap crap.
                        Get Panasonic FC/FM/FR from CPC. If you order more than £10 it's free delivery.
                        Be careful - Panasonic also sell "NHG" and "G" caps, these are not suitable. Only use FC, FM, or FR series.
                        By version - I mean there are several variants - may not just be v.1 but also different load variants so you need to check what's on your set's board.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          That will be fine although i'd buy from cpc or rs as they will both be cheaper than ebay. And also less likely to be fake.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            There's no minimum order required for cpc or rs at the moment.
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              Load variants,where how do i check ~?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4977
                                • New Zealand
                                Read the capacitors values\voltages off the capacitors on your own board and write them down. Then go order replacements that match.
                                -David VanHorn
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  http://cpc.farnell.com/webapp/wcs/st...&storeId=10180
                                  http://uk.rs-online.com/web/c/passiv...um-capacitors/ this site is slow.
                                  Both have the option to filter by brand or product range. Select Panasonic on the rs site or FM FR on the cpc site (They seem to have stopped stocking FC).
                                  You can then select by value/voltage and whichever size is closest.
                                  • dragon3x
                                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                    by dragon3x
                                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                    power on.
                                    Here are some examples :
                                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                    switching supply area).
                                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                    than 6.3 V.)
                                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                    I replaced capacitors with aluminum-polymer.
                                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                    03-21-2025, 02:46 PM
                                  • slybunda
                                    AA and AAA battery charger capacitors?
                                    by slybunda
                                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                    it has inside:
                                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                    2 x 470uf 16v LZ105c branded as G.Luxon
                                    not heard of these brands are they any good?
                                    iv attached photos of the charger and the board inside for an idea on the type of...
                                    12-24-2023, 04:41 AM
                                    by sam_sam_sam
                                    After all of...
                                    07-13-2024, 08:14 PM
                                  • Ady2017
                                    Are there any datasheets available for Elna RJG capacitors?
                                    by Ady2017
                                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                    05-25-2025, 02:19 PM
                                  • ctroxtell
                                    Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                                    by ctroxtell
                                    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                                    01-03-2025, 08:57 PM
