problem with psu in Samsung 32"
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi there guys i have a Samsung LE32A457C1D which has the BN44-00214A PSU, when i first got the tv i noticed a burn / bulge mark on the back of the tv but when i popped off the back i nnoticed it is the big cap that is causing this, not too sure whether to switch tv on or not, does anyone know what could be the issue ?
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Re: problem with psu in Samsung 32"
    https://drive.google.com/open?id=0B8...ZnM&authuser=0
    https://drive.google.com/open?id=0B8...TEE&authuser=0
    https://drive.google.com/open?id=0B8...dlE&authuser=0
    https://drive.google.com/open?id=0B8...NnM&authuser=0
    https://drive.google.com/open?id=0B8...eG8&authuser=0
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      Can anyone see the pictures in those links ?
      • vinceroger69
        • Mar 2012
        • 6714
        Yes pictures work ok but still better to add as atachments if you can just in case google drive link does not work in future. I would remove that capacitor measure height/width and order a new one certainly looks like its got hot.
        • flocko
          • Nov 2012
          • 1121
          Also remove all the brown glue crap from the board as this goes conductive and will short components out
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            ok will order one and remove all the glue and let you guys know how it goes when replaced.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Yep that capacitor let go and go so hot it melted the back cover!
              I wonder what made it go like that....must have spewed a lot of stinky smelling steam!
              I'd also suggest that you replace all the other electrolytic capacitors on this PSU, they are known to fail.
              -Ben
              Muh-soggy-knee
                Check that blue disc cap next to that big cap also, looks like the glue already turned conductive and the legs may be eaten away.
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  -Ben
                  i most always replace the capacitors on these boards, never had to change the big one though, and i will double check that budm.
                  • katinkapicinyke
                    • Mar 2020
                    • 12
                    • United Kingdon
                    Hi All,
                    Sorry to resurrect such an ancient topic but dealing with an issue on the same model (Samsung LE32A457C1D) with the same PSU board. Did checks on the cold side of the PSU board, no sign of the 12V+ outputs (on turning on I get the same 5 red LED flashes and then nothing). That dreadful glue was all over QB802 and CP811, de-soldered QB802 (Fairchild D526-Y NPN transistor maybe?) and removed the glue, however the transistor test appears to be failing between B (with positive probe) towards E (negative probe) and C (negative probe) in diode mode with my super basic MM.
                    Can I order a D526-Y off from Aliexpress for a few bucks and try replacing that on its own?
                    Also, I'm measuring 84.2 uF for CP811 (schematics suggest 47uF...) but my MM is quite a cheap one, could the capacitor ok and just the meter off?
                    Is there anything else worth checking around which usually goes at the same time when QB802 is blown?
                    2nd post only, please be gentle but any suggestion would be appreciated!
                    • neilc6
                      • Nov 2015
                      • 1550
                      If you search BN44-00214A, you will find a full page of posts for this board.
                        • 12307
                        • U.S.
                        Maybe check some new batteries with your meter to check it for accuracy.
                          1) Can I see straight shot pictures of top and bottom side of YOUR board?
                          2) What Voltage do you get on E, C, and B of the QB802 if you put the Transistor back in place?
                          3) You said you do not get 12V, how about the 24v?
                          4) There will be no 12V or 24V if PS-ON is not present, so do you have PS-ON control Voltage?
                          • katinkapicinyke
                            • Mar 2020
                            • 12
                            • United Kingdon
                            First of all, thank you for all the above suggestions, much appreciated.
                            I've got a 1k resistor installed between SB and PS pins on CNM802, still no output on 12V/24V rails (I can measure 5.2V on the SB, also around 4V on PS once it is connected with the resistor).
                            With the above jumper in place, I'm only measuring about 324-330V on the big cap (CP803).
                            With the above jumper in place, I'm getting the following on QB802 (relative to HOT side GND of CP803):
                            Base:16.15V
                            Collector:23.9V
                            Emitter:0.04V
                            without the above jumper in place, I'm getting the following on QB802 (relative to HOT side GND of CP803):
                            Base:0.4V
                            Collector:26.33V
                            Emitter:0.2V
                            Once again, thanks for your time while looking into this.
                            • katinkapicinyke
                              • Mar 2020
                              • 12
                              • United Kingdon
                              Base:16.15V
                              Collector:23.9V
                              Emitter:0.04V
                              Base:0.4V
                              Collector:26.33V
                              Emitter:0.2V
                              One more thing please, with the mainboard, TCON and inverter connected I get 3.3V of SB constantly (would I be correct assuming logical HIGH sent back from the mainboard?) while powered up, it drops only for a mere second, so like goes to logical LOW (0V) and then back to 3.3V.
                              • katinkapicinyke
                                • Mar 2020
                                • 12
                                • United Kingdon
                                Also, thank you for your suggestion, I read the below but found them inconclusive in my case, almost appeared to me as SMPS fault on mine with no obvious symptom.
                                https://www.badcaps.net/forum/showth...ht=BN44-00214A
                                • katinkapicinyke
                                  • Mar 2020
                                  • 12
                                  • United Kingdon
                                  Thank you, just did that but appears to me the same outcome when measuring that elco capacitor.
                                    • 12307
                                    • U.S.
                                    Check DB801,DB802.
                                    • R_J
                                      • 9607
                                      You are on the right track,
                                      Base:16.15V
                                      Collector:23.9V
                                      Emitter:0.04V
                                      The emitter voltage is missing, either due to an open QB802 or you have too much of a load on the M_VCC line. Check the resistance across CP811, this will give an idea of where the problem is.
                                      You could have a bad ICP801S, or bad ICM801, or it is possible CP811, CP805, CM807, CM814 are shorted
                                      • katinkapicinyke
                                        • Mar 2020
                                        • 12
                                        • United Kingdon
                                        Base:16.15V
                                        Collector:23.9V
                                        Emitter:0.04V
                                        Thank you, I can see no short on CP811, CP805 (took me some time to find, little SMD bugger!), neither on CP805, CM807, nor on CM814.
                                        The resistance between the two legs of CP811 is around 4.5K Ohm, give or take due to my meters tolerance.
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
