Sharp LC-70LE750U horizontal lines then no picture (Error code: 2-5 blinks)
  • CLquasi
    • Jun 2015
    • 9
    As an owner of 70LE750U, I feel like a trainer of rarest pokemon, I could barely find any information on this model...
    Anyway, I have this TV for about 18 months. The issue first appeared to be some distorted picture:
    VIDEO: https://youtu.be/EC6z9kbRSBI
    In the beginning of experiencing this issue, the picture would be fine for minutes after the TV is just switched on, then it gets worst and good picture would then only last for seconds. Now the TV goes blank when switched on, and the LED indicator gives the error of 2 long then 5 short blinks. According to the service manual from a similar model from another thread (LC60_70LE745U_C7450U_SM.pdf), it's the "Panel power supply error" error:
    PANEL_POW
    Panel 12V failure
    Flashes fast 5 times
    DET_PNL12V (34pin) failure (L). Panel power is not
    applied.
    Detection is started after turning on the panel power and
    receiving command; the power is turned off by polling.
    Based on the symptoms, I was assuming the issue is power supply related and hoping to resolve the issue by replacing the "Sharp RUNTKB118WJQZ (DPS-254BP-1) Power Supply / LED Board".. well, until I saw the Sharp TECHNICAL TIP 1541 from another thread:
    Model :
    Almost all Aquos TV’s
    Sympton:
    TV does not Power ON, exhibiting blink code of 2 Long & 5 Short
    Cause:
    Defective/Broken Panel, or Tcon defect
    I am now unsure how to toggle the issue, it seems it could be the T-con board, power supply, or the worst case... the panel... Any idea what to do next? Any help would be appreciated.
  • sordids999
    • May 2013
    • 2155
    Re: Sharp LC-70LE750U horizontal lines then no picture (Error code: 2-5 blinks)
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • paulstef
      • Dec 2013
      • 724
      Start by measuring the voltages coming from the power supply. 12V , 5V etc do you have those?
      • CLquasi
        • Jun 2015
        • 9
        Thanks for your response. I just opened the back, there are 3 major boards I see:
        • CLquasi
          • Jun 2015
          • 9
          Hi, paulstef, I do have a multimeter, but I am not sure how to use it... I assume I turn to 20 under DCV? Where do I point the red/black pins to?
          (I have done PC assembly and stuffs, I can replace boards, but I am no electrician... Sorry for my lack of knowledge.)
          • paulstef
            • Dec 2013
            • 724
            Yes to 20V DC.
            You can connect the black probe to the chassis, which is normally secondary ground. Then measure with the red probe.
            • CLquasi
              • Jun 2015
              • 9
              Yes to 20V DC.
              Do I check those 2 spots?
              • CLquasi
                • Jun 2015
                • 9
                While in process of learning and checking the voltages, I found...
                Is that a blown fuse?
                • CLquasi
                  • Jun 2015
                  • 9
                  Nevermind, it's a ceramic fuse...
                    Given you're getting a 2-5 error code, which is panel-related, and a picture fault, I would say it is quite likely the LCD panel has failed - this would generally not be repairable (sorry)
                    • CLquasi
                      • Jun 2015
                      • 9
                      Thank you for the reply... Yah, based on the error code, it does seem hopeless... I guess I was just waiting someone to hit me with the truth... 18 months... This is the shortest lived TV I have ever owned.... (What a shame... Even my 1997 Sony CRT still works like champ!)
                      Thanks.
                      • CLquasi
                        • Jun 2015
                        • 9
                        Strangely, when I attempt to check the power supply, the TV turned on, the 2-5 code went away, but I still get distorted picture. Is it possible that the issue is somehow not the panel, or am I just beating a dead horse...?
                        I got 12.55 from the pin below, is that within the acceptable voltage?
                        • budwich
                          • Jul 2015
                          • 3097
                          did you do anything more with this? I (my friend) have a lc-70le757u with the same 2-5 code. The "shop estimator" basically indicated a "panel replacement". Got the service manual for the set but it doesn't include the schematic of the PD board (the others are there). I just got the set in a place that I can start with the disassembly but your statement about the sharp technical tip isn't very encouraging... :-(
                          I too, can't believe a set that is basically 1.5 years old has a panel failure from basically just sitting there. His set never had any picture problems and basically was turned off at the end of day and then next day, there was no "turn on".
                          One question, besides checking you voltage (which appears correct based on my reads), is have you removed the board and looked at the components on both sides to look for issues. The reason I ask, is top side things look fine but on the bottom side, there appears to be a diode (MUR260) that appears to have a "changed solder state" (ie. looks cold as opposed to the shiny others). Without the schematic, I don't know what that particular one does but there is a significant count of them on the board. I hope to start metering those along with some voltage checks as soon as I can figure out how to get at the connector pins safely.
                          • jetadm123
                            • 2169
                            Seen quite a few Sharp 70" failed panels on this forum. I wonder if all their 70" models are using the same panel?
                              I think the LE6xx and LE7xx have to be Sharp's least reliable models for sure.
                              • noisykid
                                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                by noisykid
                                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                12-30-2024, 07:15 PM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • jaco2d
                                Sharp 50bj2ke horizontal lines
                                by jaco2d
                                This is only my seond post and so far i am very impressed with the forums.
                                I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                                The small white box thing in the pics is not the tv its a reflection from the window
                                Any suggestions...
                                11-01-2022, 04:45 PM
                              • Ihandyrepair
                                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                by Ihandyrepair
                                Hi guys
                                I just started fixing 4k TV few months ago. so I am still learning a lot
                                I got this tv from friend complaint is ghosting or horizontal lines on image.
                                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                then it started to show the ghosting white image.
                                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                it has 3 thin small boards at the bottom of the...
                                12-05-2022, 04:18 PM
                              • x_orange90_x
                                Samsung UN46C8000XFXZA Horizontal lines
                                by x_orange90_x
                                I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                07-15-2023, 05:06 AM
