Panasonic TC-P50VT20
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    I can hear relay clicking upon power up of set. Immediately gives ten blink code on LED. If I hold power button blinks stop. Any ideas where to find a service manual?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50VT20
    yeah, but first get you a meter and check across Sc2 pins and see if shorted on Sc board, if not short check on SC , Q661 RJP63F3A IGBT ( heatsink with 2 transistors bottom left corner as mounted in TV)and see if that's short, check IC521 for evidence of burn or hole in top, check IC771 resistance centre pin to output side resistance
    • tw2005
      • Oct 2011
      • 6458
      http://elektrotanya.com/?q=showresul...at2=schematics
      Limit 2 per day with no login
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        SC2 pins show 1.8M ohms, not shorted. Q661 is good, however, it's twin Q660 is shorted to ground. Visual inspection of IC521 revealed no evidence of burn or hole. Could not find IC771 for the life of me..looked with lit magnifier for 30 minutes. Also found D422 shorted as well as D641 and D642.
        Checked SD card slot for any metallic objects and found none.
        That is called out in this troubleshooting guide I found as a possibility when ten blinks are evident.
        Also, there is no LED lit on SC board during initial startup or afterwards. Also no LED lit on SS board.
        • tw2005
          • Oct 2011
          • 6458
          yeah, ok . mixed bag of results there. could be on the wrong track, I'm assuming potential Sc failure but no LED lit and 1.8meg on Sc2 is not what I would expect so could be genuine 10 blink elsewhere.meaning SC is ok, difinitely not shorted . Suggests the vsus is not being turned on at all.
          With q660 etc, we're just checking across the 3legs to see if short. If you've gone ground to each 3 on Q660 then 1 leg is grounded so will indicate short to gnd. I have a good one here and i get a short to gnd on 1 leg.
          With the TO220 package diodes 2 legs are Anode, 1 K cathode so A-A will be short, you'd have to confirm how you're doing it.
          probably would not bother with IC771 now,
          disconnect Sc2, Sc20, ss11, backprobe p2 or p11 for vsus as it starts up. If no voltage then we'd have to follow the 10 blink flow charts.
          • tw2005
            • Oct 2011
            • 6458
            If relays click then immediately 10 blink could be A board sub voltages. I'd follow the 10 blink guide in that trainer.
            After Power SW ON,F_STB 15V outputs at P6’s pin 9, 15V outputs at P6’s pin 1 before Shutdown?
            If the above is true suggests A-board.
            i have a feeling if the D board is isolated from the A, it too can trigger panel on. I'd have to see if that's been tried in another VT post .
            can't remember off hand.
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Q660 all three legs shorted to ground. Previous owner says that he replaced A Board and SMPS with no change so he returned the boards and reinstalled originals. His wife made him replace tv..hehe
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                I will do as you said and disconnect sc2 sc20 ss11..then measure voltage on p2 and p11..are those plugs or pins?
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Will also check for 15v on P6 pins 9 and 1 before shutdown.
                  • tw2005
                    • Oct 2011
                    • 6458
                    either one, that's the 2 power leads from the P board to either ss or sc for Vsus so with the cable removed it'll be pins, with cable connected, I guess the SC or SS end will be a socket.
                    • ljintexas
                      LJinTexas
                      • Jan 2015
                      • 669
                      I have Vsus of 208 volts going to both SC and SS unplugged from both boards.
                      P6 pin 1 I have 15.9volts..PIN 9 I get 0volts. if I plug in SC and SS 0 volts at Sc2
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        When I unplug harness from A board, I have 15.9 v leaving pin9 of P board. This would sugest that the A board is drawing the voltage down.
                        • ljintexas
                          LJinTexas
                          • Jan 2015
                          • 669
                          I also have 15.9 volts on pin 7 of P6. Looking more like A board. Your thoughts?
                          • tw2005
                            • Oct 2011
                            • 6458
                            have to think but this is somewhat interesting. Would suggest vsus is being shorted. measure resistance across SS pins at SS11 pin 1 - pin 3 (Vsus), might as well measure pin 3-pin 4 15V.
                            I don't think we should jump for the A board yet
                            • tw2005
                              • Oct 2011
                              • 6458
                              leave harness off and check resistance on A6, pin 6,7 or 8 - gnd.
                              i think I need to brush up on the f15V section though, I'm more curious about vsus at this stage.
                              • tw2005
                                • Oct 2011
                                • 6458
                                out of curiosity, when you fired it up with sc2,ss1,sc20 removed, what blink code did it shutdown with?
                                I know reading your original 10 blink at plugin implies F15v or related short on sub 9v or sub 5v but the no vsus with ss/sc then reappearance with those isolated suggests something wrong there too
                                • ljintexas
                                  LJinTexas
                                  • Jan 2015
                                  • 669
                                  I will measure resistance of pins on A6..I assume this is the socket on the A Board? Going to my real job now should have more info later today. will re-enact the condition with the sustains unplugged and observe what led code I get. Will also re-enact Vsus without harnesses plugged in and then with plugged in.
                                  Thanks for taking the time to assist. I appreciate your help Tw
                                  LJ
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    I'll do my best, never touched the Vt series but a lot can be correlated back to the standard FHD G20. I may be going about this the long way but I'd rather have a full feel of it all. was this your own TV and it quit or a repair job? Any history on what happened , like died after a storm or just normal use?
                                    I'll be going to work when your coming back by the sounds of it, 1122pm here.
                                    yeah , at the A board end since you feel the F15 is not there and suspect A board bringing it down that would suggest short on the A
                                    • ljintexas
                                      LJinTexas
                                      • Jan 2015
                                      • 669
                                      Bought it as a non working unit...from original owner. From what he said, it exhibited signs of coming on more slowly than normal in the weeks before it puked..then did not come on at all.
                                      • ljintexas
                                        LJinTexas
                                        • Jan 2015
                                        • 669
                                        Also said that when it failed was not around any stormy periods as in lightning. He ran it on a UPS with surge suppression.
                                        I do that on my more expensive larger sets.
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Rensiee
                                          Panasonic TH-50PX8EA Black screen, only relay clicks
                                          by Rensiee
                                          I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                          I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                          When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                          I have measured the voltage in the VSUS line, which...
                                          06-18-2024, 12:58 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • DodgyTech
                                          60" LG 60PB690V relay clicking issue
                                          by DodgyTech
                                          I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
                                          I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
                                          I would like to try and identify...
                                          07-07-2023, 10:30 AM
